Blown Circuit Breaker
Old Aug 13, 2007 | 08:43 PM
murraydeluxxxe's Avatar
murraydeluxxxe
Default Blown Circuit Breaker
I blew the power door lock/power seat control circuit breaker, put on a new one, worked for 60 secs, then that one blew. Any thoughts to what could be causing it to repeatedly blow?
Old Aug 13, 2007 | 10:49 PM
jfb's Avatar
jfb
The wire from the circuit breaker is shorted to ground. You need to trace this wire/s and find where it is and correct it. I don't understand how you can blow out a circuit breaker. The breaker is a thermal breaker, if it trips, it resets when it cools off and it will continue to trip and reset even with a short circuit until you turn the ignition off.
