Speedometer Tach Instrument Bezel
Old Aug 14, 2007 | 02:57 AM
BTU83's Avatar
BTU83
Default Speedometer Tach Instrument Bezel
I plan on changing my Speedometer Tach Instrument Bezel cover piece on my 84 Corvette with a new one, since the original is cracked and faded. My only concern is removing the headlights pull button in order to do this. Anyone know the secret behind doing so?
Old Aug 14, 2007 | 06:33 AM
86PACER's Avatar
86PACER
Right behind the **** there is a raised metal peice. You need to sit in the driver's seat, and press in the metal peice from behind towards the **** itself with a small flat tip screwdriver. And at the same time, pull the **** straight back towards you. Make sense? Need pics?
Old Aug 14, 2007 | 02:39 PM
BTU83's Avatar
BTU83
Thank you. I will try that and post results.
Old Sep 14, 2007 | 01:33 AM
BTU83's Avatar
BTU83
Easier than I thought! Thanks!
To Speedometer Tach Instrument Bezel
