Starter bolts coming loose?
Old Aug 14, 2007 | 10:44 AM
Fartleker's Avatar
Fartleker
Default Starter bolts coming loose?
About 3 years ago I changed the starter on my '89. Recently, it has been giving me more problems starting, so I went under there to check things out. My plan was to pull the starter and get it tested to see if that was the problem. While under there, I noticed that the starter was loose. I tightened the bolts, and now everything is working fine again.
My question is what would cause the bolts to come loose after 3 years? Is this something that I should be worried about?
Thanks!
Old Aug 14, 2007 | 11:38 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Did you loctite the bolts.... i usually use Blue loctite on the starter bolts...or maybe you didn't torq to spec... both may be the issue...
Old Aug 14, 2007 | 12:24 PM
Keystring's Avatar
Keystring
Thanks!
Vibration.
You're not dealing with the 'rust bucket' syndrome of the North East.
When I lived in California, just about every nut and bolt vibrated loose on a pickup truck I bought.
I've had the starter nearly fall out, the shocks come loose and 'oval' out the mounting holes. AND the bell housing separate from the engine.
Fun.
To Starter bolts coming loose?
