Front rotor thickness
Old Aug 14, 2007 | 12:29 PM
wheelsup's Avatar
wheelsup
Default Front rotor thickness
Does anyone know what the thickness is for a new front rotor? Brakes are stock 12" on a 91.
Old Aug 14, 2007 | 12:59 PM
Aardwolf's Avatar
Aardwolf
Some are stamped on the inside with it. For mine, I got them at NAPA. NAPAonline.com lists the min. thickness on their site for the ones I have. If you know what brand they are, maybe they are listed.
Old Aug 14, 2007 | 01:04 PM
wheelsup's Avatar
wheelsup
The rotors are OEM.
Old Aug 14, 2007 | 01:09 PM
LD85's Avatar
LD85
According to this site, 20mm Stock, 28mm HD
http://www.zeckhausen.com/Chevrolet/Corvette_C4.htm
Old Aug 14, 2007 | 02:35 PM
jakers's Avatar
jakers
St. Jude Donor '06
Default Standards
Standards 12" rotor is .875 inches and the 13" HD rotor is 1.125"
Old Aug 14, 2007 | 02:41 PM
ultraviolet70's Avatar
ultraviolet70
Nominal Thickness Except Heavy Duty Front Rotors 0.795 in
Heavy Duty Front Rotors 1.11 in
Minimum Refinish Thickness
Note: All brake rotors have a discard dimension cast into them. This is a wear dimension, not a refinish dimension. Any rotor that does not meet specifications should be discarded. Except Heavy Duty Front Rotors 0.744 in
Heavy Duty Front Rotors 1.059 in
Old Aug 14, 2007 | 03:23 PM
wheelsup's Avatar
wheelsup
Thanks to all who replied.
To Front rotor thickness
