hey guys, im building a 406 for my '84, the "impersonator" motor i am copying used vortec 174 intake runners, then went to AFR 180 intake runners, had 525 ft lbs of torque, and 490hp, is that a better street/strip head than say......195 intake runners? will i lose a ton of torque? just want you guys to weigh in on this one. thanx, Bill
Those were the AFR CNC 180s which flow very well, but have since been replaced by the Eliminator series which flow even better. I think you'd gain everywhere with AFR 195s Eliminator Street head; which is a lot less expensive than the CNC version. I've heard who makes the Jeggs head but I forget. It won't flow like the AFRs though (280 CFM). You could improve on that Flat-tappet cam they used too; it's a pretty old article, especially if you went to a Roller (230/236). Top it off with 10-10.5 pistons, Headers, and a Single-Plane EFI intake. JMHO
I have had 200cc performance iron heads on motors as small as 350 CI and they still did very well, even on a high rise carb intake manifold.
But with a smaller intake port head, you should still have slightly more torque on the bottom revs just because air port velocity into the intake would be a lot faster than that of a larger CC head.
Basically I'd get a head with the smallest intake port that meets the CFM of air flow for the intended power you would like to make. If torque is your primary focus, go with a smaller port head for increase air flow velocity.
This is just supposition on my part, but w/ 406 CID I think you'd maintain torque, and increase HP because of the add'l flow. I've got some older AFR 195s on my 421, and I dyno'd 504 at the rear wheels. Again, just my thinking, but 195 is still a smallish runner on a big cube motor
i believe you guys are 100% right! I dont think i can go wrong with the 195's because of the CI's, I did as was suggested and stepped up to a newer lunati Voodoo cam with 489/525, (flat tappet) roller money isnt in the picture right now, my firebird sold YESTURDAY!! so im in more of a pickle to get the car finished on a budget, things sure go astray fast! thought i would have time since i didnt advertise it well, just sitting in front of my music store in small chiefland (hootersville lol) but i need the money for these heads and just ordered a Dewitts radiator, AFR's are nice cnc bolt on from the factory, but if i get a nice set of alum heads from a local speed shop, he can machine em out pretty close i think, and i can save about $500. (pays for the rad) this forum is the best, there are no smarter people out there than here! thanx.
