I have purchased a 6 speed and want to convert my 4+3. I have serched the forum but can't find anything on the conversion. Has anyone done this and if so what should I look out for. Any help would be appreciated.
Did you try the advanced search?? 1) click search
2) click advanced (bottom)
3) Type in Zf swap....etc
4) click on archives at bottom
5) click C4 tech.
Central Coaster is the resident guru for the swap, I'm sure he'll check in. If not I'll check back in if I can help.
2016 C2 of Year
2015 C3 of Year Finalist
Speak with SK Speed (or performance) in New York. Ask for John. He is the guru on transmission conversions on C4's. Central Coaster is very helpful on this forum also.
Reuse your 4+3 speedometer sensor (VSS). Getting the 37 tooth driven gear to mesh requires installing the speedo sensor upside down (180*)and tweaking the hold down clamp a bit. Or you can just get the correct VSS, GM # 25007224
The 3.07 ring/pinion makes 6th gear unusable under 85mph. I recommend upgrading to a 3.45 or 3.55 ratio for L98s.
