PKE/Security/Starter-Kill problems are DRIVING ME MAD!
I pulled the battery cable, and reconnected it.
I had the PKE system "re-learn" the key fob.
I had a new key made.
If I start the car in the morning, it ALWAYS starts. If I start it when I am leaving work, NOTHING! No click. But, I do get dash lights, radio and plenty o' volts to start her. Windows work, etc.
If I screw around with #26 PKE fuse, let it sit for a while, it will start up perfectly.
I really don't want to take this car to a dealer. Is there anyone out there that really understands the whole PKE/security system function so I don't replace every part in the car? Anyone know how to trouble-shoot this?
Re: PKE/Security/Starter-Kill problems are DRIVING ME MAD! (Patrick96LT4)
my 96 gave me fits because of the anti theft switches on the door locks. i took
the advice i received on the forum and so far so good. my problem was some
different, my interior lights stayed on all the time and my pke would shut itself
down after about 20-30 min. every morning i would have to unlock with the keyes and it would function ok as long as i didn't leave the car idle for to long.
with some advice i received on this forum and some head scratching i removed
my door panels and inspected the switches which are attached to the door locks with a clip and they were both corroded. i replaced both for $30.00
i don't know if this will help any !!!
Re: PKE/Security/Starter-Kill problems are DRIVING ME MAD! (paul 86cpe)
I now this might sound wierd, but since it's been driving you nuts, why not go without it for a week. See if that's actually what's causing it, or if it's the Vats, or something else. Just shut the PKE off, and use only the keys. Put the PKE's out of range of the car and see if you still have the same symptoms. Might be worth a shot, before going to the dealer.
Sounds like the VATS to me. If your key is new, maybe your ignition switch is bad. From what I have read previously your VATS shouldn't kill your starter if it is reading the proper key resistance. (I could be wrong though). In addition, it could be working in the morning because your car is cold and your ignition switch internals are tighter (thermal contraction/expansion of metal).
Re: PKE/Security/Starter-Kill problems are DRIVING ME MAD! (merrick)
Patrick,
I guess none of the things we thought of sound like they helped but I think we're narrowing it down. With the #26 fuse out the PKE should be out of the picture. I am starting to think it's the VATS as well. Since you got a new key we can pretty much rule that out. I will look in my Haynes manual tonight.
Guys, thanks for looking into it. I can't imagine how painful it would be to take apart the steering column.
Any way to disconnect the VATS system... and let it just start with the key, and not read the chip?
Other then 2 special tools that can be borrowed from auto zone.. to take a column apart is not too bad. I have done it.. in fact I just put most of mine back together.
To bypass the vats you can either get the vats bypass from MAD or. we can use a resistor that is the same value of your Key and wire it in as a bypass. Fairly simple.. Let us know what you decide...
Can I install the VATS bypass myself, is it a big project? Where does the bypass go? Steering column, under dash?
Well I just looked in MAD.. the VATS Bypass is only 86-89.
Sounds like your cylinder has a loose contact. Ohm out the pellet in your key and email me the value. I will create a VATS bypass circuit for you to try.
The guy at the dealer said it was a 7.
I looked at the MAD catalog too. :(
I will certainly try your creation!! I can't wait!
Patrick, that '7' is the dealer #.. I think.. the keys range from 7-16. did he say 7 ohms? if you have an ohn meter.. put it across the 2 tabs on the key. That is the # I need. Thanks
if you take the hush panel off from below the driver side. there is an orange shielded wire that runs to the ignition switch. is has a 2 wire connector that then runs to the CCM/ECM I believe. My mod will plug into the harness side of that connector.. If it does not work, you may have a flakey CCM
