HP increase with electric water pump????
Old Aug 16, 2007 | 05:41 AM
The Bus's Avatar
The Bus
Default HP increase with electric water pump????
Has anyone actually measured before and after on a Dyno to see if there was any increase in HP?? If so how much and what engine, L98,Lt1, Ls1, cubic inches or what ever ?????. I read there should be up to 20HP which I know is BS but wonder if 10 HP could be picked up.
Old Aug 16, 2007 | 08:43 AM
GT40_GearHead's Avatar
GT40_GearHead
interesting subject !
bump for you
Old Aug 16, 2007 | 08:51 AM
dtpmike's Avatar
dtpmike
I remember researching this subject myself and found a page with someone who dynoed the difference. It was ~10-15 hp at max rpm.
The higher rpm you are at the more hp you free up with an electric.
Old Aug 16, 2007 | 10:19 AM
rickneworleansla's Avatar
rickneworleansla
I think this one's old but...
http://www.ws6.com/mod-14.htm
Old Aug 16, 2007 | 11:50 AM
vader86's Avatar
vader86
around 10 usually on LT1
Old Aug 16, 2007 | 02:55 PM
MFS's Avatar
MFS
When I had my 70 LT1 on my chassis dyno, the fan belt came off on the third pull, it picked up 11 hp at the tires at 7200 rpm's. I beleive the HP gain will be lower on a late model LT1 because it does not drive the alternator.
Old Aug 16, 2007 | 06:09 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
LT1/4's hate heat, LSX engines are a little less sensitive since they have a plastic intake manifold.
You can really cool down the car with one, at least I can with mine.
It also runs real cool around town.
Old Aug 16, 2007 | 07:17 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
If you drag race it is the way to go .10.70 to a 10.40 and 2 mph,adverage.
Old Aug 16, 2007 | 08:11 PM
aboatguy's Avatar
aboatguy
Nathan Plemon's dyno'd his car with an EWP, I haven't seen him around lately so here's his site:
http://www.wku.edu/~nathan.plemons/htmls/waterpump.html
Old Aug 16, 2007 | 08:25 PM
jonecap's Avatar
jonecap
I'm not sure of the horsepower gain, but when I put an ewp on my car it went from a 12.60 to a 12.19 with no other changes, except cooler air. As I recall it, it was about 20 degrees cooler, but the car ran consistent 12.30's after that, so it definitely made a difference.
To HP increase with electric water pump????
