Auxillary cooling fan
Old Aug 16, 2007 | 12:05 PM
JohnyH's Avatar
JohnyH
Default Auxillary cooling fan
88 - L98
I have the auxillary fan in front of the AC and rad, I just replaced the rad and did a complete flush plus added water wetter. I would like to switch the fan on when the temps exceed 230. This rarely happens but I'm on my way to Carlisle and when in traffic it does climb quite high! I'm old school and when I see those types of temps I panic. Can I just run a switch to the sensor located below and inbetween the #1 and #3 spark plug? I would assume that it goes to ground to activate the fan?
John
Old Aug 16, 2007 | 12:31 PM
Aardwolf's Avatar
Aardwolf
You run the green wire with the white stripe to ground that is on the fan relay. The aux fan relay is on the drivers side top of the radiator shroud. The main fan relay is on the drivers side wheel liner by the M/C. Solder on a wire and run it into the cabin through the boot under the drivers side hood latch. Solder that wire onto a switch and then run the other wire to ground, I used a wire connector with a round hole that went under a nut by the steering column. I drilled a hole by the ALDL and attached the switch there. I am not sure the aux fan will help, I removed it on mine as extra weight and noticed slightly less cruise temps without it. I have just the main fan on a manual switch and only use it at the track.
Old Aug 16, 2007 | 12:40 PM
JohnyH's Avatar
JohnyH
When I see the temp's climb and it's hot out the AC is on and the fan is running on the engine side of the Rad, I just thought that running the auxillary fan would help it out a bit more? When stuck in traffic it the temps scare me!
John
Old Aug 16, 2007 | 12:49 PM
Aardwolf's Avatar
Aardwolf
John
How hot does it get exactly? Mine does not get that hot. Yours might need the space between the radiator and condensor cleaned. Debris builds up, look in the gaps by the radiator cap down in front of the radiator. Does it have new coolant? If the main fan is running the aux fan running to isn't going to do much.
Old Aug 16, 2007 | 02:47 PM
CFI-EFI's Avatar
CFI-EFI
Since you just replaced the radiator, I doubt you have debris in between the radiator and condenser. You assume correctly that the auxiliary fan switch between the #1 & #3 plugs in your '88, grounds the primary side of the aux fan relay, activating the fan. You can run your manual switch wires to either the fan switch in the head or to the fan relay. However, your aux fan switch is probably set at about 237°. So you may not really need to make a change. Other than the manual switch you cold buy a slightly lower temp fan switch.
RACE ON!!!
Old Aug 16, 2007 | 03:08 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
88 - L98
John
Just replace the boost fan sensor with a lower temp one. They are @ $15 US. Mine comes on at 205* off at 185*. I haven't exceeded 220* even in the current 105* weather.
Old Aug 16, 2007 | 03:14 PM
SunCr's Avatar
SunCr
But plenty of Vettes left the Factory with one fan and never saw 230. With a new radiator, I agree that air flow probably isn't a problem. I would, as a starting point, see what the ECM is seeing and when it's turning on the Fan. You can also compare those findings to your Display - often a few degrees hotter because that signal is from a different source. Hook up a scanner and check it with a/c on and off. With the a/c on - it should be a few degrees cooler. Repost your findings. Running the Aux fan with the Main - for extended periods of time - can easily overtax the alternator. When that happens, the fans will slow down and the temps will creep back up.
Old Aug 16, 2007 | 05:03 PM
JohnyH's Avatar
JohnyH
RACE ON!!!
You are correct, I just want a safety factor (switch)!
Old Aug 16, 2007 | 05:04 PM
JohnyH's Avatar
JohnyH
Where do I find them?
Old Aug 16, 2007 | 05:21 PM
Aardwolf's Avatar
Aardwolf
Press the store button at the top of the screen.
Old Aug 16, 2007 | 05:56 PM
89 Bob L's Avatar
89 Bob L
A switch is a simple solution!!!!1
Old Aug 16, 2007 | 06:12 PM
BADDUCK's Avatar
BADDUCK
I got mine from Mid America. Large auto parts stores may have them locally.
Old Aug 16, 2007 | 06:17 PM
JohnyH's Avatar
JohnyH
"on at 200 degree and off at 185 "
So as not to burn out the fan, a switch to turn it on at 220 and off at 200 is what I would need! Or at least something in that range, or I'll just wire in a switch and turn it on when the traffic gets stopped and it needs more cooling!
John
Old Aug 16, 2007 | 06:53 PM
BADDUCK's Avatar
BADDUCK
You won't burn out the fan but if you do, so what, theyr'e $40.
Old Aug 16, 2007 | 06:59 PM
Aardwolf's Avatar
Aardwolf
John
The manual fan switch cost me $2 for a switch and an hour of my time. The kits are pretty expensive.
Old Aug 16, 2007 | 08:00 PM
CFI-EFI's Avatar
CFI-EFI
John
Even higher would be better, especially for the auxiliary fan. With some careful shopping, you can buy a stock switch for a different application and avoid the Corvette tax the Corvette specialist try to rip us for.
So send me a couple.
RACE ON!!!
Old Aug 17, 2007 | 06:58 AM
JohnyH's Avatar
JohnyH
RACE ON!!!
I agree 100% but the local GM shop isn't very helpful on that question?
Has anyone here tried do this and found a part number?
John
Old Aug 17, 2007 | 03:09 PM
CFI-EFI's Avatar
CFI-EFI
John
I have. That is how I got mine. My part number won't do you any good because the temps are too low for what you need. Neither the GM dealer nor a national chain parts store will be able to help you. With either of them, it's make, model, and year, then they give you the wrong part. They don't know, don't care, and the computer doesn't tell them the values of any given switch. You will have to get with an "olde tyme" parts store that has catalogs, books, and a REAL parts person, or someone that will let you use their's. First, you look up the stock switch. Then you go to the back of the book to the "numerical listing" section. Find the part number your car uses. Make note of the specs for that part; the connection type (there maybe a pic), the thread size (3/8" NPT), and the on/off temps. Then go through the numerical listings until you find one with the specs you want or the closest to them. Have fun, and...
RACE ON!!!
Old Aug 17, 2007 | 09:22 PM
JohnyH's Avatar
JohnyH
I'll give it a try! Thanks for the how to!
John
To Auxillary cooling fan
