"SYS" displayed for average MPG
1996, Auto, LT1, Black on Black, with 60000 miles
The following is edited from another recent post of mine:
"SYS" indicates that one or more error codes has been set in the CCM/ECM. It may be because of the aftermarket radio, or one of those computer modules has seen a problem with one of the many other functions they control.
To be thorough, check codes as shown here: http://www.corvettebuyers.com/c4vettes/codes.htm
You'll need to scroll to the end to find the correct ALDL pins to jump for '96. If my understanding is correct, any codes that will flash "SYS" can be seen this way, but you must keep in mind that '96 is OBDII and that this method does not access the PCM codes (these set the check engine light) as suggested by that site.
If the aftermarket stereo is indeed the cause (as it is for me), it is because the computer is not seeing the circuit which dims the stock radio display. The associated code, IIRC, is C72.
