Rotors off Ebay - Experiences ???
Old Aug 16, 2007 | 01:27 PM
Danspeed1's Avatar
Danspeed1
Default Rotors off Ebay - Experiences ???
Hello,
I need a set of new brakes for my 89 Corvette. Already used the search option and all I found was alot of debate about slotted and drilled. I already ordered Hawk HPS pads, a New left rear caliper (frozen), and a new emergency brake cable.
I checked the prices on ebay, and found them to be very reasonable compared to autoparts store and dealer pricing. I do not care if they are slotted and drilled, slotted, or drilled, whatever.
Best bang for buck is what I am looking for. I just want to find out who has had good experiences with sellers online and their products. I want to make sure the rotors are not going to be warped out of the box.
Dan
Old Aug 16, 2007 | 01:38 PM
wro87's Avatar
wro87
You really don't want any compromise with your brakes. Watch what you get, (what country) not much performance difference with sloted, drilled, or cut. I have used some of the cheaper brands from the auto places and found that those made in the USA cost more but are far superior to finish and warping
Buyer Beware!!
wro87
Old Aug 16, 2007 | 01:39 PM
Darkgh0st's Avatar
Darkgh0st
Old Aug 16, 2007 | 02:07 PM
runner140*'s Avatar
runner140*
I purchased a set of slotted 13" rotors from Hawks Racing and Hawk hps pads and they hook up real well.
The above was purchased over a year ago (18000 miles) on eBay.
Old Aug 16, 2007 | 02:23 PM
all show and more go's Avatar
i picked mine up at ebay,i think the only reason there drilled and slotted is for looks,i u think about it u loose surface area with drilled and slotted ones,mine are starting to get rust only after 4 months,thats my only complaint!
Old Aug 16, 2007 | 02:36 PM
Danspeed1's Avatar
Danspeed1
Yea, those are the ones I was thinking about going with. Hawks Racing.
I agree slotted and drilled are probably worse because of the lack of surface area, and slottled only have performance benefits at extremely high speeds under very hard braking but aren't any better or worse on the street then standards.
How are those hawks racing rotors holding up against rust... thats another concern?
DG
Old Aug 16, 2007 | 04:07 PM
rickneworleansla's Avatar
rickneworleansla
The center area on mine started to rust. This won't effect performance but if you have ZR1 rims it's pretty noticeable. I think I'm going to pull mine off soon and paint them.
Old Aug 16, 2007 | 04:34 PM
Red Guts's Avatar
Red Guts
I get mine at NAPA. Cheap and no problems with 4 Vettes over the last 10 years.
Old Aug 16, 2007 | 04:41 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
The NAPA rotors are generally Raybestos. Also, the last time I was at NAPA, I was tolds that their rotors were guaranteed to be ready to go out ofthe box with no machining necessary. DO NOT make the assumption that most rotors are balanced and correctly machined out of the box. ESPECIALLY if they come in a simple white box with few markings (Chicom).
Old Aug 16, 2007 | 05:19 PM
CRV3TT3's Avatar
CRV3TT3
i got my zinc plated drilled/slotted rotors, ceramic pads, ss lines and DRM spring off ebay payed $500 for all of it!!
9 months running and zero rust on the rotors!
Old Aug 16, 2007 | 05:46 PM
InHot's Avatar
InHot
I use these with good results.
http://www.powerslot.com/
Old Aug 16, 2007 | 07:48 PM
Danspeed1's Avatar
Danspeed1
I was on the fence between these and the Hawk's racing rotors. I finally wound up going with the Hawks racing rotors because of the price difference. They have pretty much the same description. I also am only replacing the rear rotors; over the winter I will try and get some better quality rotors for the front when I do the C5 conversion. Ill repost after the rotors are installed.
DG
Old Aug 17, 2007 | 08:25 AM
Da Mail Man's Avatar
Da Mail Man
.picked up (NEW) both front and rears about 5 weeks ago on e-bay made by raybestos....fronts cost me less then $5 and rears cost approx $15....total cost for both with shipping was approx $45-$50..........i went with standard rotors because i have talked to some shops that will not turn slotted or drilled rotors because it either screws up the machine or are susceptible to cracking....
Old Aug 17, 2007 | 09:45 AM
runner140*'s Avatar
runner140*
DG
Good question! I drive in the rain at least twice a week, and after one year, no rust to date.
Old Aug 17, 2007 | 08:55 PM
Danspeed1's Avatar
Danspeed1
Very Good,
Thanks again for the quick response and the help.....
Thanks to all...
DG
Old Aug 17, 2007 | 09:09 PM
cv67's Avatar
cv67
St. Jude Donor '05
Always check new rotors no matter what.
If you go NAPA or auto store replacements, they will usually have a cheapie and a "good" set. Dont skimp on rotors, youll regret it .
Old Aug 18, 2007 | 12:32 AM
1990Redcoupe's Avatar
1990Redcoupe
While I do not recommend buying rotors based soley on price I have found the best prices at www.rockauto.com They have a wide variety of rotors to chose from.
To Rotors off Ebay - Experiences ???
