Window question
Old Aug 16, 2007 | 10:33 PM
biglou71's Avatar
biglou71
Cruise-In VI Veteran
Default Window question
Ok, I have done a search, and didnt find exactly the issue I am having, so i will ask.
My passengers window, on my 88, goes down fine, however, sometimes it will come up fine, other times I have to repeatedly press the switch. Sometimes as many as 15-20 times before it comes back up. So, until I know what the issue is(switch, ribbon, regulator) I am just going to leave it up, which sucks.
So I ask you all, which issue does this sound like?
Thanks!
Lou
Old Aug 16, 2007 | 10:45 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
It would help to know what year we are talking about, but I'd say bad window switch, weak motor, in that order of likelyhood. Remember a bad switch on one side will sometimes effect the other window. The ribbon usually just breaks.
Old Aug 17, 2007 | 06:21 AM
Happydad's Avatar
Happydad
Originally Posted by biglou71
. Sometimes as many as 15-20 times before it comes back up. .
Thanks!
Lou
After 15-20 times does it go up at normal speed???? If so it's most likely the switch........
Old Aug 17, 2007 | 08:08 AM
biglou71's Avatar
biglou71
Thanks for the help, and its an 88 Coupe.. I thought I had posted that, if not, my mistake.
Old Aug 17, 2007 | 02:18 PM
89 Bob L's Avatar
89 Bob L
Sounds like the switch.
Old Aug 18, 2007 | 09:57 AM
formerfoxbody's Avatar
formerfoxbody
It's the switch, same problem with mine. I swapped it with the power lock switch on the passenger door since it's the same switch and rarely used.
Old Aug 18, 2007 | 09:59 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default window
To Window question
