Which band clamp for exhaust?
Well there is 2 I am looking at, I dont want anything to wide or big, but anything is better than the u bolts that are on the back right now.
It is an 3" slp catback, and everything is slip fit together, but I believe the pipes do not have the notch cut into the side to get them really tight. I am just interested in getting the 2 rear ones for right now, as those are the only visible ones.
I think the #2 ones look like they would be a little loose on the 1 pipe that overlaps the other pipe.
What do you think, #1 or #2?
#1:
#1:
I see the stock clamp that holds the catback to the stock maifold is the #1 style, it seems to work good.
Thanks for the info, im going to make up my mind sometime tommorow.
I used the #2 type, double bolt, and it didn't work. I couldn't tighten the thing enough to squeeze the slits I have in my eliminator pipes.
I tried clamping at the edge of the joint, and in the middle, and I still got leaks, and I could turn the pipes with the clamps tightened as tight as possible. (I used Napa band clamps)
They looked nice but, I had to go back to the u-clamps.
