L98 fuel psi question
Old Nov 6, 2001 | 05:47 AM
importeater's Avatar
importeater
Default L98 fuel psi question
you know, no one has ever told me exactly how fuel psi is rated on these. i mean there is a 10lb difference with and without vacume. when someone says get it around 48psi..do they mean 38psi at idle with vacume? or? just curious about the tech explaination on this. :chevy
Old Nov 6, 2001 | 10:27 AM
ZylaRace's Avatar
ZylaRace
Default Re: L98 fuel psi question (importeater)
You give no reference to your question.
Injectors are rated at x amount of fuel @ y amount of pressure. For GM, that pressure is 3bar = 43.5psi That means you have 43psi @ the injectors w/o vacuum.
The engine vacuum is used to reduce the fuel pressure @ the injectors. The result is an increase in fuel pressure when you loose vacuum (blip the throttle). It acts like an accel pump shot (from the carb day's).
Old Nov 6, 2001 | 10:54 AM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
I always thought it was at Idle with no vacuum.
Old Nov 6, 2001 | 05:15 PM
gcrouse's Avatar
gcrouse
Default Re: L98 fuel psi question (Marcho Polo)
Yeah- what Craig said. Fuel pressure is measured at idle with the vacuum hose pulled off the regulator. Increased fuel pressure increases injector flow rate, as well as providing better spray patterns and atomization.
Old Nov 6, 2001 | 05:33 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Our injectors are rated at 22lb/hr at 43.5psi; that's steady state flow.
I believe stock fuel pressure is 44psi with the vac hose disconnected (simulates WOT condition).
Indeed fuel flow increases as the SQRT of the pressure increase.
Old Nov 6, 2001 | 11:20 PM
importeater
Default Re: L98 fuel psi question (65Z01)
i thought as much guys, just wanted to double check as i've ran 44psi with vac & it's pretty rich, right now i'm at 39psi with vac attached or just under 50 with no vac & it seems to be stronger, run smooter & not sputter on occasion like it did with higher psi
To L98 fuel psi question
