Rear Window Defogger
Old Nov 6, 2001 | 08:27 AM
Polar LT4's Avatar
Polar LT4
Default Rear Window Defogger
My rear window defogger seems week. With light frost or even condesation, it takes 15 minutes to clear. By then I'm on the highway & the water blows off. It is working, as I can see the frost/condensationb move off over the wires before the rest of the winshield. Is this as fast as the rear defogger is supposed to work?
Old Nov 6, 2001 | 09:38 PM
Crazy Canuck's Avatar
Crazy Canuck
Default Re: Rear Window Defogger (Polar LT4)
No. I had some problems with my defogger recently as well. Now that it is working, when there is fog on the glass, after I hit the switch, I can almost immediatly see the fog slowly move away from the wires. I'd say less than a few minutes to evaporate all fog. My problem turned out to be a loose hatch strut. Try turning the struts by hand and see how tight they are. They should be quite snug as the provide the electrical connection to the defog wires.
Old Nov 7, 2001 | 04:08 AM
tan85vet's Avatar
tan85vet
Default Re: Rear Window Defogger (Crazy Canuck)
Hmm, that could be the reason why mine is almost useless as well. I have another question. The light stays on for about 2 or 3 minutes when i turn it on, the it goes out by itself. Is there a relay I should change or something? or is it not making contact at the shock, and thats causing it to turn off early? It is really not effective when it is on in the first place. How would you go about checking the system?
Old Nov 7, 2001 | 10:28 AM
Shark ssn591's Avatar
Shark ssn591
Default Re: Rear Window Defogger (tan85vet)
check the voltage @ the wires supplying the defroster (should be battery voltage) when turned on. If it is low there is a bad connection... realy or through the "strut"
with the power off verify continuity across the wires (of the defroster)
To Rear Window Defogger
