Air pump
Old Aug 18, 2007 | 06:02 PM
ronwright's Avatar
ronwright
3rd Gear
Default Air pump
Has anyone out there ever eliminated their AIR pump? What are the pros and cons? Thanks, Ron
Old Aug 18, 2007 | 07:25 PM
86PACER's Avatar
86PACER
Pros: Looks better. Quieter.
Cons: Overpriced
Or make your own:
http://members.shaw.ca/dankai/Air%20...Delete%20Info/
Old Aug 18, 2007 | 07:45 PM
dock351's Avatar
dock351
St. Jude Donor '06
Yes. lots have eliminated it. Most people buy a delete bracket. expensive for what you get. Doubt if it helps performance, but does clean up the engine bay a bit. Lots on this here on the forum, just do a search
Old Aug 18, 2007 | 09:23 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
You would know that answer if you used the search function.... being new its a good idea to learn how to use this tool... Search, Advanced, Archive posts, pick forum (general/tech)... 90% of all your new questions have already been answered many times before... plus its a great learning tool...
Old Aug 18, 2007 | 10:04 PM
williammackean's Avatar
williammackean
St. Jude Donor '07
I did it on my '85. Very happy. My ride lost 30# AND an annoying hiss that it was causing. Add to that a MUCH cleaner engine bay and I am truly tickled.
I did pay the $150 for the pulley. But I also did the 2-piece underdrive kit at the same time. Once I got the right belt it was all good.
Noticeable improvement on the butt-o-meter.
Old Aug 19, 2007 | 11:41 AM
wpsrea's Avatar
wpsrea
How about the system on an LT1? Electric pump, etc.?
Old Aug 19, 2007 | 03:34 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
http://forums.corvetteforum.com/show....php?t=1774454
Old Aug 19, 2007 | 04:10 PM
LouisvilleLT4's Avatar
LouisvilleLT4
Fill out your profile, man. I have no idea what year of corvette you're talking about, and that makes a big difference when you're talking about the AIR pump. I removed the AIR system entirely from my LT4. It's easier to remove on the LT1/LT4 engines because it isn't belt driven. All that equipment weighs under 10 pounds on the late models, but the engine bay is 100000 times more accessible without all that plumbing. I no longer need to move anything aside to change my spark plugs; I just reach in and change them.
To Air pump
