High Stall converter heat
Old Nov 6, 2001 | 09:47 AM
Greenvette's Avatar
Greenvette
Default High Stall converter heat
Does anyone have any data on the amount of heat which has to be dissipated due to the added friction of a high stall converter? Any ananlysis done to estimate the life expectancy of the trans using a higher stall converter with added cooling of the trans fluid? Does anyone use added insulation under the console area to suppress the heat build up of the higher stall converter? Thanks in advance!!!
Old Nov 6, 2001 | 12:45 PM
vader86's Avatar
vader86
Default Re: High Stall converter heat (Greenvette)
if you increased the stall of your TC then you need to buy a tranny cooler. Any stall over about 2400 would need it if you wanted the transmission to last.
Old Nov 6, 2001 | 01:03 PM
nickd's Avatar
nickd
Default Re: High Stall converter heat (vader86)
Precision Industries does not require an additional trans cooler with thier higher stall converters.
However, I agree it's cheap insurance.
"An additional oil cooler is not required for high performance converters used in typical street or strip applications although added cooling is a good thing.Care should always be exercised when runup is made at the start line. Any excess time at stall puts the converter at risk due to heat build up. This type of heat buildup would not be saved with a cooler due to the time involved to get rid of the heat. If a vehicle is to be used in towing, an added cooler is a must. However, for normal use, added cooling is not required. The better the converter is designed, the more efficient it will be and the lower the amount of heat that is generated."
Old Nov 6, 2001 | 01:13 PM
BobMachus's Avatar
BobMachus
Default Re: High Stall converter heat (nickd)
Right, I read that too, but I am gonna get a cooler when I get my Vigilante, as suggested, it is cheap insurance.
Old Nov 6, 2001 | 01:26 PM
jpee's Avatar
jpee
Default Re: High Stall converter heat (BobMachus)
I went with a Vigilante 2800, & I also installed an extra cooler, & the trans will run about 185 deg in the highway (65-70 mph) however if I'm going slow 30-40 especially UP a long hill, the trans temp has gone as high as 225..
When I drive around town (the converter is never locked up) I always try to take it easy.. I also keep my digital gauge set to trans temp..
I have an analog gauge for water temp, oil temp, & oil pressure, so I always keep an eye on trans temp..
At the track its no problem as I have over 1/2 hr between rounds..
Old Nov 6, 2001 | 01:34 PM
Mojo's Avatar
Mojo
Default Re: High Stall converter heat (Red96Coupe)
Stupid question, but where do you mount the tranny cooler?
Old Nov 6, 2001 | 04:23 PM
nickd's Avatar
nickd
Default Re: High Stall converter heat (Mojo)
In front of the radiator/AC condensor is the best place for it, you want to get as much air as possible.
John, did you ever have the trans temp gauge hooked up before you installed the converter
& cooler ? Just curious what normal trans temps are like with the stock converter & no additional cooler on these cars.
[Modified by nickd, 2:23 PM 11/6/2001]
Old Nov 6, 2001 | 04:30 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I was told by Patt Barrett at Level 10 that their 12" 2,400rpm stall lockup TC doesn't require additional tranny cooling but that higher stall should have it. And remember that as you add torque you raise the stall or flash point of the TC.
Old Nov 6, 2001 | 08:17 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Mine is mounted on the P/S cooler. Didn't want it in the rad area because i've got a bottom breather air intake so i didn't want to introduce anymore heat to that area.
Old Nov 6, 2001 | 08:53 PM
jpee's Avatar
jpee
The trans temp gauge is standard equipment on 96s. Before I changed converters, on average my trans temp was about the same.....except when going up hill, or stop & go traffic... with the stock converter it would stay around 200... with the Vig. & cooler, it still gets to 220 + in hot weather, or on hills...
BTW my cooler is mounted in front of the trans cooler also..
Old Nov 7, 2001 | 08:25 AM
nickd's Avatar
nickd
Thanks, I did not know that.
Old Nov 7, 2001 | 09:37 AM
L98Terror's Avatar
L98Terror
W. Detroit Events Coordinator
Cruise-In VII Autocross Champ
What is too hot? When are you in danger?
Old Nov 7, 2001 | 03:33 PM
mackeyred96
Default Re: High Stall converter heat (L98Terror)
I would try not to run it higher than the motor oil temp.
To High Stall converter heat
