Confused!?!?!? Please help me!
Old Nov 6, 2001 | 11:54 AM
C4@your_door's Avatar
C4@your_door
Default Confused!?!?!? Please help me!
I was wondering what this problem can be; when I accelerate I get kind of like a small back and forth vibration. (Kind of like the shaking right to left) It feels like it is coming from the back area but I’m not a hundred % sure. It will happen in the beginning and then when I speed up to a normal speed it seems to get better or I just can’t feel it because I’m going faster. I hope that I’m making sense because I want to get this fixed but it is hard to describe.
Old Nov 6, 2001 | 12:39 PM
BobMachus's Avatar
BobMachus
Default Re: Confused!?!?!? Please help me! (C4@your_door)
hmmm, My first guesses would be:
posi going south
very bad rear suspension bushings
tires WAY out of balance/round
very bad half shaft u-joints
remember..these are guesses.
Old Nov 6, 2001 | 01:05 PM
C4@your_door
Default Re: Confused!?!?!? Please help me! (BobMachus)
How would I locate these possible things that may be wrong. I'm some what car ILLITTERRATE!
Old Nov 6, 2001 | 03:18 PM
C4@your_door
TTT
Old Nov 6, 2001 | 03:45 PM
starfighter's Avatar
starfighter
well you should get the car up in the air you will have to get a good look at all the parts under the car at the rear suspension to see if there is anything that is broke loose or what ever sorry that I don't have a more specific answer for your prob.
Old Nov 6, 2001 | 04:18 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Since you're not familiar with car parts, you need to have the rear suspension, drive components, etc checked.
You can jack the car and rotate the disk brake rotors to check half-sheft U-joints.
A visual and feel will isolate loose or badly work suspension.
A torque wrench will show up a failing/bad posi though you will need a tool to span the lug nuts. If no U-joint problems you could just lay a patch and check the strips for equal darkness as a crude test and you will need the torque spec on the posi.
Old Nov 6, 2001 | 05:28 PM
C4@your_door
Default Re: Confused!?!?!? Please help me! (65Z01)
Thanks I will get this checked out. I need to find a damn corvette specialist in my area. Does anyone know how I would go about finding a specialist in my area? I live in Fairfield county are in CT.
Old Nov 7, 2001 | 11:46 AM
C4@your_door
To The Top
Old Nov 8, 2001 | 08:12 AM
Geoff13IOM6GS's Avatar
Geoff13IOM6GS
It's a long shot but ...... check your tire pressure.
I had the strangest slight vibration when I would first drive my car. I would get a slight vibration for the first 7-10 miles then would run smooth as butter. This problem came up when the weather started getting cold. I tried letting the engine warm up but that made no difference. After about a week of this my 'LTPWS' light came on. I put air in the tires and the vibration went away.
Old Nov 8, 2001 | 06:46 PM
C4@your_door
Default Re: Confused!?!?!? Please help me! (GSMVette 919)
Yeah that was what I first thought but I checked the air pressure are they were fine. I had new rear brake pads put on last weekend. Could that have anything to do with it? I check and the lugnuts are on tight.
Old Nov 12, 2001 | 11:55 AM
C4@your_door
TTT
Old Nov 12, 2001 | 04:04 PM
GRX's Avatar
GRX
Rear-end suspension alignment. :flag
To Confused!?!?!? Please help me!
