Finally got it running!!!
Old Aug 19, 2007 | 04:28 PM
force fed's Avatar
force fed
Default Finally got it running!!!
Well,
Since Jan. the 89 has been torn down to the block all because of a lower intake leak and after a head job (ported with 2.02 and 1.60), full exhaust, pro magnum rr, miniram, throttle body, and hypertech dist. it idles fine but, once you give it gas it falls on its face and wants to die out. I idled it to the gas station 3 blocks away for some fresh gas and just made it back home. I was thinking that either the idle air set screw is not set right or the tps is not set right. It kind of seems like ...well... I'm not sure but, any suggestions would be great! Oh, and it already had a Vortech kit with #30 injectors on it before I began the tear down.
Old Aug 19, 2007 | 05:14 PM
PurtyLilC4's Avatar
PurtyLilC4
I would look into ignition problems, it could range anywhere from bad plugs to a dead distributor. The entire system between those, it could be as simple as a bad ignition module. Basically it's getting gas but not enough spark. Of coarse you've also got tps and IAC , honestly theres a list of things that could cause this, my first instinct however would be to go through the ignition.
Old Aug 19, 2007 | 05:54 PM
force fed's Avatar
force fed
thanks for the quick reply but, I put in new plugs (ngk v-grove), new wires (msd 8.5), and a hypertech coil so I am not thinking that it is the ingition unless it would have to do with timing accept it is idleing good and I think that the computer would advance or retard timing if needed. I am a novice so I am not sure though.
Old Aug 20, 2007 | 03:16 PM
force fed's Avatar
force fed
Can someone please suggest a good base timing so I ca nat least drive it to a shop to get it tuned? Would -6 work?
Old Aug 20, 2007 | 11:15 PM
AKS Racing's Avatar
AKS Racing
6° BTDC will work fine for basic driving. The ones I have done were able to use a lot of timing for off throttle and cruise, but timing needed to be pulled as the boost increases.
Aaron
Old Aug 21, 2007 | 12:42 PM
force fed's Avatar
force fed
Well,
I tried setting timing and started at about +15 and went up to +32 which seems to run better but, the only problem is that it would fall on its face at about 1300. I am thinking that it has something to do with the computer not retarding the timing under boost or not giving it enough fuel under boost. I forgot to mention that it has a DFI on it so I am thinking that the computer needs to be sinked with the distributer for the timing and fuel. Any ideas? I think it is off to the tuner for me (its just to bad that I couldn' t drive it there. What is a good fuel pressure (45) like tpis states or higher?
Old Aug 21, 2007 | 04:17 PM
93 ragtop's Avatar
93 ragtop
Are you holding fuel pressure at the rails? What im getting at, could the fuel filter be stopped up?
To Finally got it running!!!
