383 feuel injectors
Old Aug 19, 2007 | 06:13 PM
drd21968's Avatar
drd21968
Default 383 feuel injectors
i have a 383 ,superram,what lb ijectors would this motor need.i bought it from a dealer on trade in and there are ford injectors in it i think 24 lb.part no 02080 150991.i think they may have kept feuel injectors and stuck these in.car was ronning lean when i got it putting it back together now im thinking 36 lb or should i go more
Old Aug 19, 2007 | 06:29 PM
vader86's Avatar
vader86
I would go no more than 30lbs
Old Aug 20, 2007 | 08:05 PM
drd21968's Avatar
drd21968
30 to 32 lb seems to be consistant with all sources i have asked,good call
Old Aug 20, 2007 | 08:51 PM
BTTB's Avatar
BTTB
Old Aug 20, 2007 | 09:37 PM
96lt4c4's Avatar
96lt4c4
30 lb Ford red tops will flow 32 lb of fuel in your car due to higher fuel pressure.
Old Aug 20, 2007 | 11:07 PM
dock351's Avatar
dock351
St. Jude Donor '06
FWIW on my 383 superram setup, im using 24 lb., no lean condition here at 42 lbs psi
Old Aug 21, 2007 | 04:32 PM
85 500 horse's Avatar
85 500 horse
30 lb. Bosch injectors on my 383 superram works fine.
Old Aug 21, 2007 | 05:52 PM
drd21968's Avatar
drd21968
went with 32 lb accell injectors i have a adjustable feuel regulator so i can lean it out if necessary and have a little extra for future mods
To 383 feuel injectors
