1995 runs sluggish when warm.
Old Aug 19, 2007 | 10:13 PM
klyday's Avatar
klyday
Navigator
Default 1995 runs sluggish when warm. need help
Hey;
I have a 1995 that I have changed out the Optispark,water pump, intake manifold gasket and did many other cosmetic changes but I still have a check engine light I can't figure out. I have changed the O2 sensor on drivers side due to H44 code ( to Lean) and the code came back after about 15 minutes time. When I changed the O2 sensor the old one was full of carbon at tip. I checked the pressure on the fuel rail at the relief point and had 40PSIG and 36PSIG when running. I checked the OHMS and had 12.9 and 13.0 on all injectors. Service engine light still comes on and car still runs sluggish after warming up where should I go from here? Any help would be appreciated.
