I'm looking for one to use with two belts. I want a 8 rib SC drive belt behind the standard 6 rib Alt/PS/AC drive belt. Does anyone have such a thing for the LT1 engine? ATI tells me they don't.
Contact Greg at Blowerworks. I got mine from him. Just like you wanted, 8 rib blower behind 6 rib accessory, 94 LT1 engine. It actually IS an ATI piece. Maybe they only make it for him (I believe he had a hand in the design process) and they don't realize what application it is for. It is definitely an ATI superdamper, as I have had them before and recognize the work. Tell Greg that Darren from Maryland sent you, and tell him I said hi. He can help you greatly with your project, and has several other accessories you may want or need.
Talk with Lee at ASP pulleys for a non-SFI approved conversion or you can order the 6+8 from ATI (not ATI the procharger folks, ATI the pulley folks).
CT
The guy I talked to said I could order from them directly or from one of the distributors. If you want, I can PM you his info and you can talk to him directly.
