Radiator Burp Procedure?
Old Aug 22, 2007 | 05:03 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Default Radiator Burp Procedure?
What is the proper procedure to get ALL the air out of the cooling system? Any special tricks that you guys might suggest will be greatly appreciated. Thanks.
Old Aug 22, 2007 | 05:38 AM
86PACER's Avatar
86PACER
Fill the overflow tank to the cold full mark.
Start the car and let it idle. Periodically squeeze the upper radiator hose with a rag around your hand. Once the hose is no longer hard, the stat has began to open and coolant is now circulating.
Have someone raise the engine rpm to about 2200 and hold it there. The coolant level in the radiator will drop. Remove radiator cap and fill with coolant all the way to the top with rpm's raised. Replace radiator cap before letting the rpms back down.
Drive the car normally. Repeat this once a day for the next several days, untill you can't add anymore coolant.
Old Aug 22, 2007 | 06:39 AM
Da Mail Man's Avatar
Da Mail Man
....i fill the radiator and part of the overflow tank...start the car with the cap off....when the car heats up and t-stat opens, you'll see the coolant level drop...when it does that, raise the idle to 1500+ and add additional coolant and put the cap on tight.....before the system becomes fully pressurized, raise the idle and remove the cap, add additional coolant and "button it up"......never had a problem with this proceedure...other proceedures will work just as well....
Old Aug 22, 2007 | 07:26 AM
runner140*'s Avatar
runner140*
Old Aug 22, 2007 | 09:21 AM
Aardwolf's Avatar
Aardwolf
Drill a small hole in the 'stat, then all you need to do is check the level, it burps itself.
Old Aug 22, 2007 | 09:31 AM
89 Bob L's Avatar
89 Bob L
All of the posts give great advice. Drilling two small (1/4') holes in the flange of the thermostat helps with the procedure. Others have also recommended raising the car up (on ramps) during the procedure. In addition, it is a good idea to turn the heat on.
Old Aug 22, 2007 | 09:32 AM
Sam Lam's Avatar
Sam Lam
as I have used this technique for years.
Old Aug 22, 2007 | 02:43 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Default Thanks
Great information. Thanks for getting back to me guys.
Old Aug 22, 2007 | 02:59 PM
Sam Lam's Avatar
Sam Lam
Here is a photo to illustrate how to drill the t'stat such that coolant burping in not needed:
I prefer to drill two holes either 3/32 or 1/8 inch in diameter into the body of the thermostat. Hope this is helpful to you.
Old Aug 22, 2007 | 03:17 PM
Aardwolf's Avatar
Aardwolf
Good picture. If you get a balanced type 'stat, it may have a notch in it which does the same thing.
Old Aug 23, 2007 | 06:38 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Default Thanks
Thank you all very much !
Old Aug 23, 2007 | 08:49 AM
89 Bob L's Avatar
89 Bob L
Another important factor is to put the thermostat in the right way. You would be suprised at the number that are put in backwards>
To Radiator Burp Procedure?
