Brakes fluid ?
Old Nov 6, 2001 | 07:38 PM
Eduardo L98 1991's Avatar
Eduardo L98 1991
Default Brakes fluid ?
Please help me with this :
I have a lot of problem with the poor braking of my car !
Yes, I know that exist a lot of kit (zr1,etc), maybe later.
At now my system is original.
When I brake hard and constantly the cover of my brake pump jumps and the pedal goes to the floor !
I believe that the fluid brakes that I use is very poor, but I tried a lot of brands with the same result. ( the gm fluid is not good )
Which is good ?
Maybe in my country do not exist but I can import a box.
Eduardo Castrejón Elbjorn,
Old Nov 6, 2001 | 07:44 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Default Re: Brakes fluid ? (Eduardo L98 1991)
Brake Fluid Comparison Chart in °F
Brand Wet Boiling Point Dry Boiling Point
Castrol SRF 518 590
Motul 600 421 585
AP-600 410 572
ATE Super Blue 392 536
Valvoline 333 513
Castrol LMA 311 446
Ford HD (DOT 3) 290 550
Wilwood 570 284 570
PFC-Z rated 284 550
AP-550 284 550
Old Nov 6, 2001 | 07:46 PM
vader86's Avatar
vader86
Default Re: Brakes fluid ? (PeteL)
i dont think thats exactly a brake fluid problem. Sounds more like booster or master cylinder.
Old Nov 6, 2001 | 09:50 PM
Eduardo L98 1991
I forgot to tell you that my brake fluid in the pump is gray, dark ?
why, more the front.
Old Nov 7, 2001 | 10:04 PM
No Go's Avatar
No Go
Normally, when the fluid goes dark it is sign to change it-has foreign particles in it and water(mainly water). The fronts get more abuse than the rear so may be the difference.
Unless you are really pushing your brakes on the track for long periods-I think you would be best to simply change the fluid regularly-yearly? and use what is available. I did similarly and use cheap Kmart Valvoline SynPower fluid (DOT 4). Never boiled the brakes but I did crack the front rotors!
Good luck!
Old Nov 8, 2001 | 01:15 AM
pablocruise's Avatar
pablocruise
Que paso paisa. Milagro un miembro en Mexico. Echame un grito cuando quieras. Sounds like a master cylinder to me. It happended to me long time ago, but it is very easy and very fast to fix. Condition of hoses? Any leaks or moist/soaked hoses? Wheel cylinders bleeder screws torqued down to spec? I like to use dot 4 fluid. Be careful with the high performance driving/braking until you fix this. -Saludos (-Pablo) :cheers:
Old Nov 8, 2001 | 02:48 AM
Eduardo L98 1991
Pablo: El gusto tambien es para mí, hay un chavo de Monterrey tambien.
Posiblemente haya mas pero no se porque nunca lo dicen, hasta puse
post para buscar gente de México hace tiempo y nadie respondio.
I always have this problem I already change the piston of the brake pump.
The car brakes but after a time of hard braking the fluid boil and the cover of the brake pump jumps.
I use diferent brake fluids, but I have the same problem. The best that I use is the bmw (dot 4).
Which dot is the adequate ?
Other opinions ?
To Brakes fluid ?
