yeah lpe 219 was made for it. slight lope on 350 not much on a 383 though. i picked mine up used for 215. you can probably find one on here or thirdgen if not they are 340 + shipping from LPE
Only an idiot would take apart a car that runs perfectly fine with 30K miles........I am that idiot.
you are not alone I am tearing down my perfect running 93 to do a cam swap and roller rockers/ headers and a stall convertor. torque is a drug and like another member posted stock sucks
good luck
OK, serious, I ordered 1.6 rockers. Do I need to send them back and get 1.5s?
Next question....the lift at 1.5s is .525. Will the LT4 springs work, or do I have to find other springs for this lift?
what will the lift with 1.6 be? Is it too much? Again, will the springs handle it?
Look at all the trouble you guys are causing me.....
I'm going back to PRC. It's cheaper and less work.
From memory the LT4 springs are rated to .525 so the 1.6 would be to much. I am not an expert at this though. So the 1.6 rocker would be better if you do not have enough LCA. That would depend on the cam.
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Originally Posted by senorv47
Us Bastards are trying to help you can you be alittle more respectful?
I was joking. Sorry, forgot the or Note the above when I said "serious", because above I was kidding...
I put up a number of threads about this project. It started simple enough, Super Ram, some rockers and headers, done. Then I was told "you have to do the cam", and "taking out the radiator is a piece of cake", ect....... so a relatively simple project is becoming a huge project...hence the comments about the heads above....
I was going to go with a 219 cam but decided to go more aggressive with it. I chose a Comp Cams 230/230 0.560 (with 1.5) which turns out to be a 0.598 with 1.6. This cam is on a 110 CL, so idle will be somewhat choppy.
You could still run the 1.5 and get the 0.560 lift without having to buy 1.6's.
Just happened onto this thread. Anyway, the LPE 219 ad says 1.6 rockers. So I would assume the .560" lift is WITH 1.6 rockers, not 1.5's.
I suppose a phone call would be in order if I were to be installing one, although I am not. I am an avowed CC Extreme Energy grind fan, not to put down Mr. L at all (his fame speaks for him alone). And yeah, those Voodoo's do look pretty good too.
