ECM "Learning"?
Old Aug 24, 2007 | 09:16 AM
Chris Kennedy's Avatar
Chris Kennedy
Default ECM "Learning"?
Hi:
Last night the negative battery cable on my '89 worked loose enough so that the car wouldn't start (everything went dead when I turned the key). So, I quickly got the cable tightened back up and everything came back to life. One thing I did notice is that at idle, the idle speed drops way down, then slowly comes back up to normal. It's done something similar to this before when I have had the battery disconnected, but not so severe. Anyway, I am thinking that this may be part of the ECM "learning" process the service manual talks about when the power is cut off to the ECM. Has anyone experienced anything similar?
Thanks,
/s/ Chris
Old Aug 24, 2007 | 10:57 AM
Muffin's Avatar
Muffin
Short answer: Loss of battery power removes NVRAM which stores adaptive strategies. Fuel trim is an adaptive strategy. Drive the car normally and the adaptive data will be restored. OBD 1 maby as little as 10 minutes, OBD II maybe as long as an hour. This is from "Corvette Fuel Injection " by C O Probst. Highly recommended reading BTW.
Old Aug 24, 2007 | 01:36 PM
Chris Kennedy
Thanks! I will let people know what happens, and how long...
/s/ Chris
Old Aug 24, 2007 | 01:47 PM
RRT vette's Avatar
RRT vette
Yep, dirve the car for about 15-20 miles in different conditions (idle, cruise, and WOT) and it will relearn.
Old Aug 24, 2007 | 01:53 PM
Da Mail Man's Avatar
Da Mail Man
Old Aug 24, 2007 | 02:08 PM
CFI-EFI's Avatar
CFI-EFI
Just exceed 40 mph once warmed up to reset the IAC. The idle will be straightened out.
RACE ON!!!
To ECM "Learning"?
