cooling down the beast
Old Aug 25, 2007 | 07:58 PM
85blkrose's Avatar
85blkrose
Default cooling down the beast
just picked up a new dewitts direct fit radiator at carsiles this morning. hopefully this help settle the temps of my stroker down a bit.i have read several post about these radiators and have used your comments to help me make this purchase. thanks one and all for being so informative about your projects and purchases. this helps alot of people out more than they let on. thanks again for all the info i was able to obtain from you all
Old Aug 25, 2007 | 08:08 PM
Road Agent's Avatar
Road Agent
Good luck with it!
Old Aug 25, 2007 | 10:28 PM
jfb's Avatar
jfb
I recommend you install a Stewart water pump too. 41% more coolant flow than stock which will help at idle.
Old Aug 26, 2007 | 05:01 AM
85blkrose's Avatar
85blkrose
i instaled an edelbrock high flow water pump when i put the stroker in
To cooling down the beast
