'88 Still Won't Start!!!!
2) Spliced in a start button using a power wire from the battery to the switch and splicing into the Yellow 14 Ga. wire from under the steering column
When I try to start the car, all the gauges light up with the ACC on and the bell chimes....then when I go to start the car whether with the start button or the key there is nothing. With the starter enable relay plugged back together there is a clicking noise inside where the small relay is located. This clicking occurs whether using the key or the new start button.
I have not attempted to determine whether the starter is getting juice since I would have to jack up the car. How do you disconnect the blue plug from the starter anyways to determine if it's getting any current?
Any help would be greatly appreciated.
Also, the battery light is on when attempting to start, but there is 13.8 volts and this is an old Optima battery.
Thanks!
I just tried to start it again and when using the key the battery symbol and the SECURITY symbol light up. When I try to start it with the new start button, only the battery symbol lights up.
I can hear the fuel pump with the ACC selected so I feel that this is a VATS issue.
One more thing...where is the ECM on an '88. This car has a Holley Commander computer for the engine behind the bread box. Does anyone know if this Holley Commander is a stand alone computer or needs to piggy back with the stock ECM.
If the Holley Commander is a stand alone, then the ignition VATS should be electronically disabled...Right?
Thanks!
The car started and ran fine with the Holley Commander computer, etc...prior to my pulling out the interior and door panels; (future track car)
I just looked up abov the passenger foot well on the left side and there is no stock computer, just a small junction box inside the left side of the bread box.
The clutch pedal switch looks to have been removed snd the car started like this. (there is a hole where it looks like a switch used to be).
Anyone have any ideas???
Thanks!
Verify those things and get back. I believe the Commander is taking care of the fuel, so that part of the VATS is effectively disabled and with the Start Enable Relay jumpered, that part is now disabled, so VATS should not be an issue. Forget about the Security light, it is only connected to the UTDS module and has nothing to do with VATS on an '88.
My thoughts are two-fold:
1) Rip-out all the wiring, install an aluminum dash with Autometers and re-wire to support the Holley Commander & LT-1 EFI.
or
2) Rip-out all the wiring, install the same aluminum dash and Autometers and go to carburation.
The only concerns are; I need the brake lights, the anti-skid, and the instruments. I will have a push button ignition and switches as necessary to support the engine and instruments. That's basically all I need. All the rest of the electrical; windows, door locks, heater, fan, radio, A/C, horn, lights, turn signals, reverse lights, etc will all be ripped-out.
Does anyone know what I can get for the Arcade style instrument panel...everything on the panel seems to work fine.
Thanks again!
