brake/wheel questions...
Old Aug 26, 2007 | 01:22 PM
94.C4's Avatar
94.C4
2nd Gear
Default brake/wheel questions...
First time poster here. Looking forward to being a part of the group.
I purchased a 1994 coupe last summer. I live near Road America (Milwaukee) and I've fallen victim to the siren's song of the track. I'm going to slowly convert, as $ (and the wife) permits to a more track ready car. I'm starting with brakes.
I've considered the C5 upgrade, but that entails some modification to the car. I've heard very good things about the "Baer Claw" eradispeed brake package as well. It has 13" front rotors and 12" back, as opposed to stock 11.9. From what I've read this is a good option.
Any thoughts?
Also, I'm looking for a set of "grand sport" wheels, not really for performance but just because they are cool. I'm looking to put on the 9.5's all the way around, because the 11 inch ones are just to big. There were a buch of different combo's of these wheels, and the Z-R1 wheels, with different off sets, etc... Any adivce on this? Also, anyone have a set for sale?
Thanks.
Nathan Bayer
Old Aug 26, 2007 | 01:35 PM
hgh pwr's Avatar
hgh pwr
I have the grand sport brakes on my 94 and it works very well,also i would suggest toms wheels 600.00 for a set of zr1 wheels 9.5 for all 4 or 9.5 front and the 11 for the back.Why not run the 11 in on the back ,i have them and they look and work great. welcome to the forum.
Old Aug 26, 2007 | 02:03 PM
94.C4's Avatar
94.C4
2nd Gear
Default Thanks for the advice
I'll definitely check out Tom's wheels.
As for the 11inchers in the back, don't they stick way out? The actual Grand Sport had a wider rear end than my standard 94, if my understanding is correct, and the grand sport still had those extra tack on fenders because the wheels stick out so far. Also, do you need spacers or anything? Weight might also be a consideration, as the Grand Sport had about 35 more horses.
Thanks for any thoughts you might have.
Nathan
Old Aug 26, 2007 | 02:10 PM
96GS#007's Avatar
96GS#007
Any thoughts?
Thanks.
Nathan Bayer
If you're new to road courses, you'll be fine with stock brake components, a slightly more aggressive brake pad compound, and the addition of brake cooling ducts. If you're really hot to spend the money then skip straight to an aftermarket setup such as Wilwood, StopTech, etc.
The nice thing about the 9.5" GS wheels on all 4 corners is that it allows you to rotate the tires to even out the wear.
You will also need to decide how you intend to use the car....general track day car / HPDE, or NASA Time Trials, actual racing, etc....as that will impact what mods you can make and still be legal (if you choose the later uses which are class specific/competitive events).
More than anything else you need seat time, seat time, seat time.
You may also want to visit the auto-x and roadracing section of the forum.
Welcome to the sport and bring $$$ Pretty easy to blow thru a set of brake pads and rotors in a weekend at a track like RA, not to mention how quickly you can chew up a set of tires, wheel hubs, etc. Then there are entry fees, gas, food, accomodations.....
Old Aug 26, 2007 | 02:12 PM
96GS#007's Avatar
96GS#007
Nathan
The GS has the standard width bodywork. ZR1s had the wider bodywork.
The GS rear wheels have a different offset than the ZR1 rear wheels. The flares cover the 1/4" or so the wheels stick out.
Old Aug 28, 2007 | 05:05 PM
Kinkajou's Avatar
Kinkajou
Old Aug 28, 2007 | 05:18 PM
JEFNLSA's Avatar
JEFNLSA
Welcome to the forum.
Here's a link in the C4 F/S forum for just the wheels you are looking & at an incredible price.
http://forums.corvetteforum.com/show....php?t=1798061
Jeff
Old Aug 28, 2007 | 05:41 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Any thoughts?
Nathan, there are absolutely no mods needed to go to the C5 brake kit. You can go back to stock C4 gear anytime you wish. Nobody would know the difference.
The bear claw eradispeed package is well not cheap. It is a C4 PBR with the baer logo cast into them. Do not expect them to perform any better than the stock C4 J55 caliper. The rotors in the kit I would not use for HPDE track days either.
Old Aug 28, 2007 | 06:25 PM
Aardwolf's Avatar
Aardwolf
Are you going to the Oct MFBA event at RA? I will be there again. Have you run the track yet? It's awesome fun!
To brake/wheel questions...
