install convertor or headers first??
Old Aug 26, 2007 | 02:12 PM
gator79's Avatar
gator79
Default install convertor or headers first??
I will be installing long tube headers and a torque convertor, my question is can the trans be removed with the long tubes in place?
Old Aug 26, 2007 | 02:31 PM
aboatguy's Avatar
aboatguy
I'd do them at the same time. Seems like every project I do on the vert requires dropping the X frame and pulling the exhaust. I can't remove the torque converter cover plate/panel with out pullling a header. (Trust me I tried but my EM headers don't allow it. I wanted to pull the engine with the headers attached and couldn't get that cover out of the way IOT remove the TC to Flexplate bolts)
MIke
Old Aug 26, 2007 | 02:50 PM
vader86's Avatar
vader86
The primaries shouldnt interfere, but I would still do the converter first just in case.
Old Aug 26, 2007 | 03:24 PM
Keystring's Avatar
Keystring
Take the old manifolds off.
Install converter.
Put new headers on.
Old Aug 26, 2007 | 06:22 PM
aboatguy's Avatar
aboatguy
He has a 93 which is LT1 equiped and as I stated earlier, my EM Long Tubes have to be removed in order to get to the torque converter. Maybe other brand's of LTs don't.
Mike
Old Aug 26, 2007 | 06:59 PM
fredk's Avatar
fredk
Did my 93 this spring and did not have to remove my EM's
Fred
Old Aug 26, 2007 | 10:00 PM
aboatguy's Avatar
aboatguy
Fred
Fred
OK, I wonder if the converter cover is different on the 4l60E than the 4l60/ 700R4, or if your AFRs make the difference, or the milling of my stock heads moved the header collectors that much.
MIke
Old Aug 26, 2007 | 11:18 PM
gator79's Avatar
gator79
Install converter.
Put new headers on.
I think thats what I will do. I am doing a cam swap at my shop at home and it would be easy to put the headers on now. but I will do the convertor at my work where I have access to a lift. I will do them at the same time. gives me a good chance to soak all the bolts with penetrating oil. the front bolt on the driver side is backed out all the way hope the threads are good
Old Aug 27, 2007 | 10:34 AM
fredk's Avatar
fredk
My 93 has AFR heads and EM headers and it was no problem. I have the 4L60.
Fred
To install convertor or headers first??
