MSD Optispark question re: timing adjustment
The only alternative that I've found is the MSD unit, however a forum search reveals that half of the buyers reporting on this board have reported problems with them or other MSD ignition products. The only thing that piques my interest about them is that the timing can supposedly be adjusted via a screw.
Does this feature have any value on an otherwise stock engine?
Thx!
When I recently built a 388 for my 96, I had PCMFORLESS re-burn my PCM. The timing curve Bryan programmed in is predicated on the Opti timing being as stock.
Unless I'm wrong, adjusting the timing using the aftermarket Opti effects the entire timing curve.
I'd rather not fool with the entire ignition timing curve. I'd rather go with Byran's programming to tweak any timing change I might decide to try.
Jake
Jake
On a stock motor (like mine), the timing adjustment is no big advantage,
you won't use it. Stock LT1's don't have any timing marks anyway.
According to MSD, the timing at idle is controlled by the ECM. If you're adjusting the timing with the MSD, it should be done above 1,500 rpm.
For a 92-93 with the non-vented Opti, I sure wouldn't put another GM on. Another waterpump failure would kill it. Converting to a 95 & up Opti is a pain. If I had to do it again, I'd by another MSD.
