I have accumulated most of the parts for my build and would like to know what to expect out of my setup and if i need any other parts before i get into the engine?
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Why did you go with such a big head? I am looking at basically the same mods. To maintain low end torque I will be getting 1 5/8 headers and about 60CC heads with better flow.
Any reason for the bigger headers and heads?
It is my understanding that the SR is designed for low end, the heads and headers seem to be "geared" to high end.
Why the difference? Am I thinking all wrong here?
I am going through pains to match the intake with the cam with the heads, with the headers...am I pissing in the wind?
got a good deal on the heads and they flow almost like a 180 or 185cc head due to their unique design
planning on eventually going supercharged and will need the lower compression.
also possibly adding nitrous and i think the lower C/R will help with that too.
i talked to trickflow and they said you i will gain around 35-45 hp and 20 tq. If it were better matched i would probably gain 40-50 and 25 tq.
thanks for the reply
Thanks, I only want to do this once, and I'm trying to figure it all out now...
I dont see 350rwhp coming if you are running the lowered compression.
The heads can flow enough air though. I would also say in the 320-330rwhp range.
My opinions on other questions asked: the difference between 1 5/8" and 1.75" should be minimal and you wouldnt notice, plus the larger headers will continue to be fine should you go to 383+ ci; 190cc is on the big side for a 350, but will also carry over to a 383 should you go that route. Considering what you say TF says these heads flow, I dont see any problem with losing any low end torque, the SR gives plenty to spare.
how much power can the stock drive line transmission etc. and bottom end handle?
i have heard as high as 500 hp on the drive line
and bottom end can handle up to 6500 rpm and around 500 hp also
is this correct?
Dont ask how much power, ask how much torque. HP doesnt break anything.
There is no concrete limit to what either the diff or the tranny can handle. They can each break whenever they wish. However if you keep the transmission running cool it can handle a good bit for awhile, ambiguous i know, but we just cant tell you exactly how long. The diff will probably stand up to street use for a long time, but track use will be a different story, one great hookup and it could blow, so it depends alot on the tires.
Only advice I can give to prevent it is add a transmission cooler, sooner rather than later, and dont run slicks at the track. (i'm assuming you drive an auto)
From: SCMR Rat Pack'r Charter Member..Great Bend KS
This is something many of us overlook: now much TORQUE can the driveline take?
Question for the OP: are you freshening the lower end (overbore, new rings, pistons and bearings) or are you putting these parts on a 100,000 mile short block?? This will make a small difference in power and a large difference in longevity.
(you should see somewhere in the range of 300rwhp)
