HEI ignition or something else\better??
Old Aug 28, 2007 | 06:36 PM
rickeolis's Avatar
rickeolis
Default HEI ignition or something else\better??
I'm dropping in a rebuilt 350 small-block which will be carbureted, and I'm looking for the best way to go with an ignition. I have the stock points style small diameter distributor, but am wondering if I should replace it with a GM HEI, or full blown aftermarket setup like MSD or Mallory?
I plan to race it on the road courses locally.
-Rick-
Old Aug 28, 2007 | 07:01 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
The HEI system will require less maintenance than points, while also supplying more energy to the plugs. There's several other threads which discuss the selling points and reliability issues of some of the aftermarket systems.
I'm using an HEI system in my big block. I use it for a lot of road couse track days. I'm completely happy with the cost and performance of this system.
Old Aug 28, 2007 | 08:07 PM
Matt Cramer's Avatar
Matt Cramer
I'd say go with an HEI module - less maintenance, low price, hot enough for a naturally aspirated smallblock if you don't go crazy with the RPM or compression ratio. I actually put a HEI on a Mopar slant six once.
I'm not sure a typical street motor really needs a CDI type ignition. If you'd started this post with, "Now that I've got the bugs sorted out of my twin turbo setup..." that might be another story.
Old Aug 28, 2007 | 08:52 PM
emo-vet's Avatar
emo-vet
hi guys,
i decided to buy msd equipment for my 8 throttle body cross ram intake for my 1991 vette.
i brought msd #8366 small cap dist and msd PRO coil 55,000 volt= 800 mA of spark current & one of the largest power single coils available #8201.
then i brought from Jims performance the tpi wring conversion harneses to suit and convert.
regards
shae
Old Aug 28, 2007 | 10:38 PM
69427's Avatar
69427
Originally Posted by emo-vet
hi guys,
i brought msd #8366 small cap dist and msd PRO coil 55,000 volt,one of the largest power single coils available #8201.
regards
shae
Just FYI, please beware of marketing hype. (Dielectric breakdown) voltage is not power. And, what you are looking for is energy out of the coil, not "power".
Ignition 101
Old Aug 28, 2007 | 10:54 PM
cv67's Avatar
cv67
St. Jude Donor '05
Matt Cramer is spot on.
Old Aug 29, 2007 | 10:57 AM
rickeolis's Avatar
rickeolis
That's what I was hoping to hear guys, thanks!
I'll order it today-
-Rick-
Old Oct 4, 2007 | 04:11 PM
rickeolis's Avatar
rickeolis
Thanks for talking me into it guys, I've been running my new HEI (Large style) now for a few weeks and just love it!
-Rick-
To HEI ignition or something else\better??
