That's what I was starting to realize. I was just thinking if I could
get a wrench on them somehow, I knew I was going to have to heat
them and I sure don't have much room to work with.
I grabbed a offset O2 wrench last week, but it doesn't have much of
a head to grab on the drivers side.
When I swapped engines on my 96 a couple of months ago I noticed the same thing. I've got four 02s and two are them are absolutely inaccessible without dropping the exhaust.
You should see how cut up my hands got just trying to plug one of them in!!
Sears and NAPA sell a "crow's foot" O2 sensor wrench similar to the one in the photo. That's what I used to coax mine out of my '92 without removing the cats or heat shields.
Make sure your exhaust is warm to "loosen" the threads on the old sensors. Use anti-sieze compound if it's not supplied with the new sensors.
I would also be prepared to replace the sensor connector pigtails as they get brittle from engine heat and often break when you go to disconnect the sensors. NAPA has them.
My O2 sensors on my 95 were accessible while on the the car. Not easy, but got changed. Use some spray lub (WD-40, PB blaster) and spray the threaded area. Let it sit for a bit and spray it again and wait. I used a normal tool (can't remember), but nothing special. If that doesn't work, start the engine and let it idle for a minute and try again.
I've always just taken a propane torch to my o2 sensors if they refused to budge. Usually they come out like butter once you heat them. Starting up the car is OK too I guess.
