Patriot Performance heads
Old Aug 29, 2007 | 09:32 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Default Patriot Performance heads
Anyone know anything about these?
http://www.patriot-performance.com/w...05238&DID=1225
Seems decent for the money.
Your Choice of 195, 215, or 225cc intake runners
2.02"/1.60" or 2.08"/1.60" Performance Series 21-4N Stainless Valves
Angle or Straight Plug
Bronze Guides
Patriot "Gold" .650" Dual Springs (Good for use with cams up to .650" hydraulic roller)
Titanium Retainers
Machined 10* Locks
Machined Spring Bases
3/8" Screw in Studs and Guide Plates
Viton Rubber Seals
195cc 100% CNC Ported Super Street Assembled Heads
Old Aug 29, 2007 | 09:35 PM
jsup's Avatar
jsup
Just noticed, they are the perimiter bolt valve covers. Will they fit?
Old Aug 29, 2007 | 10:49 PM
chriswtx's Avatar
chriswtx
Patriot makes some good heads. I used perimiter bolt valve covers type heads when I built my motor for my 91'. I just changed valve covers. Got some polished billet aluminum ones. But I'm not sure if they wil clear a TPI set up. They would clear a minirem setup though. I did have to clearence the AC bracket a little...
Old Aug 30, 2007 | 03:52 AM
conv90's Avatar
conv90
I have considered , then I bought Brodix.
Why I have not purchased? I don't know. Probably because No One in this C4 forum is using it.
About the valve cover: My Brodix are for perimeter and centerbolt.
In reality the centerbolt pattern is useless, due to the external ridge of the heads.
I used TALL perimeter valve covers on my 90 with the larger SuperRam and I hae plenty of room.
-Beppe-
Old Aug 30, 2007 | 08:45 AM
87 rag's Avatar
87 rag
Old Aug 30, 2007 | 09:38 AM
jsup's Avatar
jsup
I called the factory. Here's the story.
http://www.patriot-performance.com/w...03567&DID=1225
$795 plus $40 for a spring upgrade for brand new heads.
The Super Ram only flows 240 CFM according to Lingenfelter. I called them and verified that spec.
These heads will flow 260 CFM with a 64 CC chamber. They have a 62CC chamber also, I will go with the smaller one if I can get it.
I believe the standard heads are 58CC or 60CC. Can anyone verify for me that number.
I'm looking at the specs on this head and asking WTF for $800 for new heads, seems like a bargin.
The factory said that they're cheaper than AFT and others because 1. they do sinificanlty more volume and 2. they are not a stand alone company but a subsidiary of a larger company 3. they buy more volume. They buy 20,000 valves a month and more.
That's what I'm getting. Seems like a deal.
Comments welcome.
Old Aug 30, 2007 | 11:42 AM
conv90's Avatar
conv90
http://forums.corvetteforum.com/show...hlight=Patriot
Old Aug 30, 2007 | 11:45 AM
cv67's Avatar
cv67
St. Jude Donor '05
Im curious to know whose castings these originally were.
Old Aug 30, 2007 | 11:52 AM
edoad's Avatar
edoad
There is an article in the Aug issue of car craft. Good heads for the money. I bought a pair and they are drilled for both valve covers. I got an odd combustion chamber size and larger springs. $100 more.
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
113 heads have a 58 cc combustion chamber. 60 cc should be fine on your car.
Old Aug 30, 2007 | 11:54 AM
edoad's Avatar
edoad
Supposed to be Australian, probably Chinese.
Old Aug 30, 2007 | 01:05 PM
Matt Cramer's Avatar
Matt Cramer
Either way, whoever picked the brand name was a bit irony-impaired.
Old Aug 30, 2007 | 01:27 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
I just called Patriot and asked them about LT1 support. The associate I talked to, said that they were planning on having some offerings for the LT1 around the end of the year by November.
To Patriot Performance heads
