Does a 1994 C4 have a cam sensor??
Old Aug 29, 2007 | 10:03 PM
copperc41's Avatar
copperc41
Default Does a 1994 C4 have a cam sensor??
Old Aug 29, 2007 | 10:22 PM
InHot's Avatar
InHot
What is a cam sensor?
Old Aug 29, 2007 | 10:59 PM
copperc41's Avatar
copperc41
Together, the cam position sensor and crank position sensor detect crank shaft rotation during one engine-combustion cycle.
Old Aug 29, 2007 | 11:03 PM
InHot's Avatar
InHot
I'm staying out of this one!
Old Aug 29, 2007 | 11:15 PM
copperc41's Avatar
copperc41
The reason I ask is I finally took my car to a shop to fix an idle issue that only happens when the car is driven for 1/2 hour or so, and he told me today that it may be the opti or the cam sensor and as far as I know it does not have one. Just wanted some info from the experts.
Old Aug 29, 2007 | 11:30 PM
TorchRedRob's Avatar
TorchRedRob
In my experience, a lot of the japanese automakers refer to a "cam sensor" when we would likely call the part a "distributor."
I learned this when I got a "Cam Position Sensor" code on my Altima. What did I do to fix it- replaced the distributor.
I think they get the whole "CPS" name due to the fact that it uses an optical encoder.
Old Aug 29, 2007 | 11:32 PM
STL94LT1's Avatar
STL94LT1
The 94 doesn't have a cam sensor, unless that's what he is calling the opti-spark. The 96 OBDII cars have a crank position sensor.
Old Aug 29, 2007 | 11:34 PM
copperc41's Avatar
copperc41
Thanks for the info!!
Old Aug 30, 2007 | 01:09 AM
VenkmanP's Avatar
VenkmanP
The optispark contains a cam position sensor.
The mechanic saying it could be the opti _or_ the cam position sensor makes me question his knowledge of the car.
Old Aug 30, 2007 | 07:58 AM
gator79's Avatar
gator79
Old Aug 30, 2007 | 08:00 AM
Mekanic's Avatar
Mekanic
Originally Posted by gator79
To Does a 1994 C4 have a cam sensor??
