92 vert help
Old Aug 30, 2007 | 09:54 AM
excessive81's Avatar
excessive81
Default 92 vert help
i have a cust that is wanting to put a new vert top on his 92. he is wanting to go with the glass rear window but to do so you need a kit that gm has discontinued. part number 12522961 is what i am looking for. seems that all the top manuf where using the gm kit and to my knowledge no one else is making them. so....anyone got any ideas
thanks
shane
Old Aug 30, 2007 | 06:10 PM
c4cruiser's Avatar
c4cruiser
Mid-America has tops for the C4 verts and the glass window conversion kit.
Go to this link to the MAM webpage for information.
Old Aug 30, 2007 | 08:16 PM
jghmczo6's Avatar
jghmczo6
Here are two sites I recently found (do not know anything about either) however they tout having rear glass windows. Once the summer is over in Arizona I plan on putting a new top on my '90 vert. If you are familiar with either company and can recommend or give the stay away nod it would be most appreciated.
Hope this helps......................
http://www.1aauto.com/1A/Convertible...VT00361/382095
http://tops4less.com/convertible-top...corvette8.html
Old Aug 30, 2007 | 09:13 PM
vettowner1994's Avatar
vettowner1994
You can find replacement tops on ebay fairly reasonable. Just do a search there for convertible top corvette.
Old Aug 30, 2007 | 09:37 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I Bought Mind From Ecklers, And Works Real Well. I Even Have A Rear Defroster, So Look For The Wires On Right Side Under The Carpet.
Old Aug 30, 2007 | 09:41 PM
c4cruiser's Avatar
c4cruiser
Unless the 92 came with the factory hardtop (which has a defogger) there will not be a ground wire on the driver's side. The orange hot lead is on the passenger side.
One other concern will be the button that is supposed to operatethe defogger. Depending on the type of HVAC system (manual or C68 Electroninc Climate Control), there may not be a way to operate the defogger if the car didn't come with a hardtop.
This only applies to the earlier verts with the plastic window; when they went to the glass window as standard, the defogger grid was part of the new top.
Old Aug 31, 2007 | 08:12 AM
Strick's Avatar
Strick
I found the orange/black lead that goes to the defogger, but I had to install a ground for the other side of the hard top's leads. I have the C68 HVAC system with the defog button for the mirrors. I was lead to believe that the orange/black lead was on that circuit. I guess it's time to test the circuit. My vert didn't come with a hard top.
To 92 vert help
