Shifter knobs, so many choices..
Old Nov 8, 2001 | 12:35 AM
Rob 93ZR-1's Avatar
Rob 93ZR-1
From: Fear causes hesitaiton...and hesitation will cause your worst fears to come true. Houston TX
Cruise-In IV Veteran
Cruise-In VII Veteran
Default Shifter *****, so many choices..
Couple of questions, Are the threads the same on shifter for all the zf gearboxes? There is a Hurst ball shaped for 6 sp camaro I was looking at, but don't know if it will fit. Does anyone make anything that resembles the pistol grip of old HIPO MOPAR? I hate the stock ****.
Old Nov 8, 2001 | 02:13 PM
FrankLT4CE's Avatar
FrankLT4CE
Default Re: Shifter *****, so many choices.. (Rob 91Z07)
I don't have answers to all your questions, but I do know that besides the threads there is a wedge shaped steel block that is used to set the orientation so the **** doesn't rotate. At least that is how it is on my 96. In aftermarket Corvette catalogs the Corvette specific shifter ***** are much more expensive than what I expect. Maybe this wedge device is (at least in part) the reason. Please let me know if you find another shifter **** can be easily adopted. FrankLT4CE
Old Nov 9, 2001 | 12:46 AM
CELT4's Avatar
CELT4
Default Re: Shifter *****, so many choices.. (FrankLT4CE)
This place has some *****. :D
http://www.flameball.com/
Old Nov 9, 2001 | 08:40 AM
365ZUM's Avatar
365ZUM
Cruise-In III Veteran
Default Re: Shifter *****, so many choices.. (CELT4)
Contact ZRCHRIS on the forum using IM. I know he can help you out.
Old Nov 9, 2001 | 08:52 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Shifter *****, so many choices.. (365ZUM)
I have a Flameball shift ****, but if I could find a MOPAR pistolgrip, I would use that. I might get a Hurst "T" handle with the button on the side for my line lock.
Old Nov 11, 2001 | 10:33 PM
zrchris's Avatar
zrchris
Default Re: Shifter *****, so many choices.. (Mr Mojo)
C5 6-speed ***** will fit all C4 6-speed shifters. The thread size is 9/16"-18. Camaro's use a metric M16 thread that is slightly larger than 9/16". Hurst is working on introducing a C5 classic style ****, but reverse will be the wrong way. Hurst is also considering a new ergonomic T-handle for shifters like ours, in a 9/16" thread. I have modified some classic T-handles and Camaro round ***** to fit C4's , if you are interested I could do one for you. Email me if interested.
Chris
To Shifter knobs, so many choices..
