Vette Not Running Right... Please Help
Old Nov 8, 2001 | 09:49 AM
yoda4x4's Avatar
yoda4x4
1st Gear
Default Vette Not Running Right... Please Help
I have an 88 Vette Anniversary Edition and just recently it started having this problem. It starts up and runs but it will not idle unless I keep my foot on the gas pedal. I just gave it a tune-up: plugs, wires... etc. What could this be?
In addition, I've noticed that it is leaking antifreeze. I've inspected the hoses and the radiator and they seem to be fine. Where else could it be leaking from?
Please help.
Old Nov 8, 2001 | 10:40 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Vette Not Running Right... Please Help (yoda4x4)
What about the throttle position sensor and the IAC (idle air control?). There
are all kinds of things on the throttle body that can cause this problem. I wish I could give you more specific info, but I'm just not that familiar with it. At least this will bring the post back up to the top so somebody else might see it. Good luck. :cheers:
Old Nov 8, 2001 | 12:49 PM
JonM's Avatar
JonM
Fuel filter is the first place to start...Its only a couple bucks...Its located on the inside of the frame just below the passenger side door.
Old Nov 8, 2001 | 02:12 PM
Camvette's Avatar
Camvette
Default Re: Vette Not Running Right... Please Help (JonM)
Check your vacuum lines. Does it run ok at operating temp? :cheers:
Old Nov 8, 2001 | 04:01 PM
SpedRacr93's Avatar
SpedRacr93
Like CamVette said, check vaccum lines. Especially ones around plenum where you had your hands changing wires.
Also, could be the water pump leaking. Mine did.
Old Nov 8, 2001 | 07:28 PM
Gregory VanLare's Avatar
Gregory VanLare
Where is the coolant leaking from? Is it showing up on top or around the intake?? The intakes do come loose (I had a major problem getting this diagnosed) and when the fuel rail came off to check it, some of the bolts came out with my fingers!!! :seeya
To Vette Not Running Right... Please Help
