Need help ASAP
Old Aug 31, 2007 | 01:48 PM
bsmutz's Avatar
bsmutz
Default Need help ASAP
Replacing EGR valve this weekend. In reading the manual, it says that there are potentially three different types of valve: positive, negative, and neutral. What I need to know is if you have to replace the valve with the same type (I'm pretty sure you must, but wanted to know what you all think). When I called around to find the best price and checked on line, nobody asked what type it was. Unfortunately, I could only find one place locally that could get the darn thing within a day that wasn't over a $100. Thanks for your help in advance.
Old Aug 31, 2007 | 07:44 PM
GKK's Avatar
GKK
Yes, use the same type that was originally installed on your "91" which is a Negative Back Pressure EGR valve.
