Intake and Exhaust CFM
Old Aug 31, 2007 | 07:32 PM
kowalski340's Avatar
kowalski340
Default Intake and Exhaust CFM
Ok folks I need some info........ I need to know the exact exhaust CFM and intake CFM of an '89 L98. I need this info to help me properly size the turbo on my new single turbo project. thanks
Old Sep 1, 2007 | 04:25 PM
kowalski340
bump
Old Sep 2, 2007 | 02:24 AM
JoBy's Avatar
JoBy
Is it a stock engine and are you going to run it stock? Stock cam?
You can use a dyno graph to get the numbers you need.
You don't need exact numbers as building a custom turbo engine is no exact sience.
Old Sep 2, 2007 | 11:04 AM
kowalski340
well in order to choose the right aspect ratio and trim of the turbo it pretty much is........I was looking for the exhasut and intake flow rates of a stock 1989 L98
Old Sep 2, 2007 | 01:48 PM
doug_dayson's Avatar
doug_dayson
Stock 89 head and various manifolds @ 28" H20.
Stock cam and rocker:
I = 176 cfm @ .410"
E = 156 cfm @ .423"
Port stall:
I = 186 cfm @ .550"
E = 162 cfm @ .560"
Stock Manifold and Runner = 198 cfm
Accel Manifold and LTR = 232 cfm
Accel Manifold and SR = 240 cfm
Sad isn't it?
Old Sep 2, 2007 | 04:35 PM
JoBy's Avatar
JoBy
The CFM numbers in and out of the cylinder head is not important by itself. It is the total package with intake, cam and everything.
You get an estimate from engine hp: Engine HP X 1.6 = airflow in CFM.
250 hp x 1.6 = 400 CFM into the engine.
CFM out depends on exhaust back pressure and exhaust temperature, but the air in plus fuel in is what comes out of the exhaust.
You size the compressor of the turbo from the boost you are going to run and the CFM of the NA engine.
Then you want a large turbine housing to keep the exhaust pressure low and you want a small turbine housing to reduce lag.
To Intake and Exhaust CFM
