What's your digital gauge settings ?
i dont like the fact that i have to look under the steering wheel to check oil pressure and coolant temp,i tried to change the angle of the wheel buy i dont feel comfortable so i better read under the wheel
What mode do you use the most ?
- English or Metric ?
- What's the correct levels under both modes ?
- What does the average mpg reads ?
i want to know more about the gauge panel
what's a correct number for coolant temp ? under fahrenheit and C° ?
it was reading 211 fahrenheit yesterday and 1xx celsius but i dont know if its OK because it does not have an "warning" light that i know.-
So can you please post your average readings on both metric and english modes
thanx !!!!!!!!!!!!!!!!
what's a good oil pressure on psi and kph modes ?
what's the correct coolant temp on c and f ?
correct volts ? yeah,between 12 and 14
what's the average gauge ? and how is it used ?
and so the trip thing
My vette's standing idle is 600 to 700 or 900 rpm
I leave mine on oil pressure and coolant temp. Nothing else really matters. I don't really care how many Pascals of air are in my tires or how many Liters I use per 100 kilometers.
Volts: 14.1
Coolant temp: 182 F cruise, up to 227F sitting.
Oil temp: around 186F, dont use it much.
Oil pressure, 60PSI.
Avg MPG, now at 23.7, but its usually about 1 MPG optimistic.
And I agree a red idiot light and the reading for the fault will over ride any setting switched on. This happened when my alternator went out; I think it came on at 11.9 Volts.
