Oil Leak
Old Sep 3, 2007 | 06:47 PM
lusor's Avatar
lusor
Default Oil Leak
My Vette has an oil leak somewhere around the oil filter area.Its been like that for about 6 months and its gotten worse.Is there any known problems in this area?
Old Sep 3, 2007 | 07:00 PM
runner140*'s Avatar
runner140*
Have you changed your oil filter and you still have a leak? Sometimes the oil filter seal leaks. Try a new filter. I put in a new oil filter adapter and my leak stopped. Try a new filter first.
Old Sep 3, 2007 | 07:54 PM
lusor's Avatar
lusor
I hope its just that.I'll try a new filter.
Old Sep 3, 2007 | 07:58 PM
jetmech09's Avatar
jetmech09
Default oil leak
I had same issue & changed the "o" ring at the filter housing assy. leak is gone
Old Sep 3, 2007 | 08:23 PM
lusor's Avatar
lusor
I think you hit it on the dot.Was it an easy job.
Old Sep 3, 2007 | 08:26 PM
jetmech09's Avatar
jetmech09
Default oil leak
not to bad if you put it up on a lift.
Old Sep 3, 2007 | 08:31 PM
lusor's Avatar
lusor
Where did you find the part ?
Old Sep 3, 2007 | 08:52 PM
jetmech09's Avatar
jetmech09
Default oil leak
local autoparts
Old Sep 3, 2007 | 09:09 PM
lusor's Avatar
lusor
local autoparts
To Oil Leak
