help with horn please
Old Sep 4, 2007 | 06:00 PM
FRANKENSTEIN4x42000's Avatar
FRANKENSTEIN4x42000
Default help with horn please
i am replacing the stock steering wheel with a Grant wheel. bought the correct adapter etc. the horn didn't work since i bought the car, i checked the fuse and connection to the horn itself it's all goo, except i don't have a horn on the left side.
when i took off the original wheel i tried to see and there is no power to the steering colum, any ideas? what color wire am i looking for?
thanks
J-P
Old Sep 4, 2007 | 06:16 PM
RRT vette's Avatar
RRT vette
What year 4x4?
Old Sep 4, 2007 | 07:34 PM
FRANKENSTEIN4x42000
Originally Posted by RRT vette
What year 4x4?
It started life as an 80, new tube chassic 2006
J-P
Old Sep 4, 2007 | 07:59 PM
86PACER's Avatar
86PACER
No, what year vette.
Old Sep 4, 2007 | 08:38 PM
senorv47's Avatar
senorv47
thanks
J-P
If you don't mind my asking ,where did you get the adapter kit? I have a Grant GT Series wheel but have not been able to find a kit. By the way sounds like you have a ground problem. You have to have a good ground in order to get power.
Old Sep 4, 2007 | 08:51 PM
FRANKENSTEIN4x42000
1986
Old Sep 5, 2007 | 03:39 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Check behind the DIC. Horn Relay or Theft Fuse.
Old Sep 5, 2007 | 08:10 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
Make sure the anti theft fuse is not blown, this is wired into the horn for some crazy reason (stupid design IMO)
my anti theft system in the door locks always go off, so I had to pull the fuse... now I can't honk like a maniac at anyone. its quite frustrating
Old Sep 5, 2007 | 12:28 PM
FRANKENSTEIN4x42000
I checked all the fuses, on the pass side, is that the only spot?
thanks
J-P
FRANKENSTEIN4x42000
Thanks i will look behind the DIC
Old Sep 5, 2007 | 12:53 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Old Sep 5, 2007 | 03:59 PM
PAINTER MAN's Avatar
PAINTER MAN
I can tell you the ground for the horn runs through the turn signal lever. The horn on my 86 would not work. I had to have the dealer replace the turn signal lever. It works fine now..
To help with horn please
