Differential Swap/U-joint Replacement Assistance
Old Sep 4, 2007 | 09:51 PM
jsavoy's Avatar
jsavoy
Default Differential Swap/U-joint Replacement Assistance
I'm getting ready for my differential swap and decided to replace the universal joints with Spicer's while I'm at it. I've read the FSM/CF threads but wanted to know from those who have already done this the easiest way. Would it be easier to drop the rear axle as a whole unit or perform on-vehicle service.
Also add any additional "TIPS AND TRICKS" you might have besides these by C4boy and Scorp:
      Old Sep 5, 2007 | 04:20 AM
      toptechx6's Avatar
      toptechx6
      John I would first remove the rear spring, disconnect the strut (camber) rod brackets from the diff and swing them down, unbolt drive shaft and axle u-joint straps at the pumpkin, bungee half shafts "up" then drop the batwing/pumpkin assembly.
      Once it is out, removal of the driveshaft and axles is easy. The driveshaft slip yoke just slides out of the transmission tailshaft. With the batwing and pumpkin out, remove the outer u-joint straps attaching the half shafts to the wheel yokes, way easier than removing the complete rear suspension.
      Old Sep 5, 2007 | 08:39 AM
      Casethecorvetteman's Avatar
      Casethecorvetteman
      Yep, do it just like the man said. Its pretty easy to do really.
      Remember to support the transmission/tailshaft housing before removing the bolts from the c-beam.
      Old Sep 5, 2007 | 09:06 AM
      toptechx6's Avatar
      toptechx6
      Good point mate, thanks for filling in the blanks.
      Old Sep 5, 2007 | 09:09 AM
      Casethecorvetteman
      No worries
      Old Sep 5, 2007 | 06:22 PM
      jsavoy's Avatar
      jsavoy
      Jim and Casey, thanks for the inputs.
      Old Sep 6, 2007 | 12:30 AM
      Casethecorvetteman
      A pleasure mate, anytime
      Old Sep 6, 2007 | 01:37 AM
      CentralCoaster's Avatar
      CentralCoaster
      From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
      Yeah, I'd drop the diff down. Much easier that way if you're doing all 6.
      BUT... I would try it without unbolting the Cbeam at all.
      Just undo the rear spring bolts,
      pull the entire exhaust in one piece,
      undo the lower camber arms at the brackets (not at the cam bolt!)
      put floor jack under the pumpkin,
      remove both batwing bolts,
      let the entire thing pivot down in one piece.
      Now you can get the driveshaft out, and both halfshafts, and you don't have to touch the wheels or the C-beam.
      Old Sep 6, 2007 | 04:36 AM
      Casethecorvetteman
      Since he says he is doing a diff swap, the diff certainly has to come out if another one is going in, and whether or not the c-beam comes out, the transmission still needs to be supported, so for the simple sake of 2 bolts id take them out myself. I tried it once without unbolting the transmission end of the c-beam and not that i tried for long, but it takes around 45 seconds to undo the 2 bolts (assuming youre using power tools) and make the c-beam easy to move
      Thats just me though, Coaster do you do this up on a hoist or on jack stands??
      Old Sep 6, 2007 | 05:01 PM
      89 Bob L's Avatar
      89 Bob L
      Nice Tips on the removal
      Old Sep 6, 2007 | 05:04 PM
      Rich B.'s Avatar
      Rich B.
      If you're taking the torque beam out (and in), then it's a real good idea to take the distributor cap off first...You'll need the clearance...
      Old Sep 6, 2007 | 05:53 PM
      CentralCoaster
      No need to remove the torque beam or distributor cap. In the gif I posted, I left it attached to the transmission, pivoted the engine/trans/beam assembly down slightly to pull the rear end off the end from it, and pulled the driveshaft out with it.
      it's on page 1 here:
      http://www.cardomain.com/ride/405346
      Old Sep 6, 2007 | 06:45 PM
      toptechx6's Avatar
      toptechx6
      Not on an LT1! And you thought everything about the Opti spark was negative!
      Old Sep 6, 2007 | 07:25 PM
      finally_got_it's Avatar
      finally_got_it
      Default Good Timing
      i am about to go thru the same procedure..this came at a great time!
      Old Sep 6, 2007 | 08:54 PM
      jsavoy's Avatar
      jsavoy
      Thanks for the tips & pix Central.
      Old Sep 6, 2007 | 10:14 PM
      Rich B.'s Avatar
      Rich B.
      My bad...I missed the part where he said he had an LT1...
      ...I'm still missing it...
      Old Sep 7, 2007 | 04:06 AM
      Casethecorvetteman
      No its not.
      you wouldnt be doing it on an L98 either if you properly supported the transmission, the engine wont move and there is no way the cap will come into contact with anything.
      Which bit are ya missing?
      To Differential Swap/U-joint Replacement Assistance
      Old Sep 7, 2007 | 05:51 AM
      toptechx6's Avatar
      toptechx6
      Profile
      Old Sep 7, 2007 | 10:32 AM
      finally_got_it
      hey james what gears did you decide to go with? the chart you sent me really helped my decision to go with 3.55's i ordered mine yesterday from ikerds
      Old Sep 7, 2007 | 10:57 AM
      CentralCoaster
      No its not.
      The engine has to drop wayyyy down before the L98 dist cap will come close.
      Even then, the wiring harness back there will hold it in place. I know this because I had a jack under the pan leak down, and it did no harm, the cap still had some clearance.
      This of course is without all the extra weight of the trans hanging off of it.. that would probably do some damage if not supported.
