Looking for suggestions on what to do next...
Old Sep 5, 2007 | 03:53 PM
bsmutz's Avatar
bsmutz
Default Looking for suggestions on what to do next...
I'm having a problem with a rough running situation (sounds like a miss). I pulled the codes and got a 32, so after much ado, I finally got the EGR valve replaced. I restarted the car and still had the big miss at idle. Going for a drive, it ran very rough under acceleration and when I tried WOT it started pinging real bad so I backed off. Not so bad when coasting. I had previously checked spark, so I decided to pull injector connectors. There was no change in idle when I pulled the connectors to injectors 5 and 7. Before I go out and spend the money on new injectors, I want to make sure that is the problem. Here's my plan of attack: First, I'll ohm out all the injectors and see if there is a problem with the coils on 5 and 7. If the coils are bad, get new injectors. If coils are good, then I need to find out if signal is getting to them from ECM using an oscilloscope or a noid light. I suppose there is a slight chance that there is a blockage in the fuel delivery to those two cylinders also. Any other suggestions?
Old Sep 5, 2007 | 04:54 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Yr helps.
Vacume leak
Cat blockage
Injectors
Old Sep 5, 2007 | 05:00 PM
bsmutz's Avatar
bsmutz
As in my profile, 1991.
Old Sep 5, 2007 | 05:45 PM
svoshop's Avatar
svoshop
This may not be of any help, but in some cars ( like my 98 Taurus SHO ) if the ECM picks up a bad miss in one cylinder, it will turn the injector off to that cylinder.
Eg, I had a coil go bad ( coil on plug ) and the ECM shut off the injector to that cylinder. I replaced the coil and still had a miss. Only to have the missfire clear up after I cleared the code out.
Just a thought... Don't know if a 91 is that smart yet.
Mike
Old Sep 5, 2007 | 09:20 PM
WW7's Avatar
WW7
If you have the stock injectors in your car then the chances are good that this is the problem. Check the ohms on the injectors, they should be around 16.5 +/-.3 . Most of the people I know that have stock (Multec injectors) have had problems and changed them out. Its not if they will go bad but when.
Old Sep 6, 2007 | 07:28 AM
runner140*'s Avatar
runner140*
An old trick may work. In a dark garage/or at night, pop the hood and start the engine and look for sparks from plug wires grounding. Or use a water spray bottle on the plug wires to look for shorts.
To Looking for suggestions on what to do next...
