Drilled Thermostat?
Old Sep 5, 2007 | 05:30 PM
svoshop's Avatar
svoshop
Default Drilled Thermostat?
I am in the process of doing my Opti and water pump. While it is all off, I am going to replace the thermostat. My question is, in one of my other cars ( Supercharged Buick Regal ) I drilled out a 180* stat with two 1/8 inch holes. The car now runs cooler by about 7* and cools down faster at the track.
The vette seems to run a little on the warm side for being a 180 stat. I was curious if anyone recommends drilling a couple of small holes to help with cooling. The stat has the jiggle valve to help purge air, so this would only help that system too...
Edit: I appoligize, it is a 95 M6.
Any thoughts.
Mike
Old Sep 5, 2007 | 05:41 PM
PAINTER MAN's Avatar
PAINTER MAN
I did drill two small holes in mine to help purge the air in the system. I had problems in the past. I changed the stock thermostat to a 160, so I can't say if the holes make the car run cooler. My guess would be it doesn't.
Old Sep 5, 2007 | 05:53 PM
svoshop's Avatar
svoshop
Did the 160* help out much?
Mike
Old Sep 5, 2007 | 06:22 PM
JAKE's Avatar
JAKE
I drill holes in the stat for my 86, 415 to help purge air. They help for that purpose.
Other than that, all they do is allow the engine to run for a slightly longer period of time before it reaches normal operating temperature. It doesn't allow the engine to run any cooler once it reaches normal op.
The stat I use in my 96 LT1 comes with an air purge hole already in it. So I just drop it in as it comes in the package.
Jake
Old Sep 5, 2007 | 09:10 PM
WW7's Avatar
WW7
I changed the 195 stat in my 89 two weeks ago, drilled the holes and the temp is the same as before. It just made it easier to fill without air in the system.
Old Sep 5, 2007 | 09:16 PM
89 Bob L's Avatar
89 Bob L
I drilled holes in the thermostat on my 89. The main intention of the holes is to facilitate the removal of air. It really does not affect the performance of the thermostat, and if anything takes a little longer to get up to opening temperature.
Old Sep 5, 2007 | 09:24 PM
TPI BOY's Avatar
TPI BOY
Did mine, no more air problems
Old Sep 5, 2007 | 10:29 PM
hippy's Avatar
hippy
I ripped the center of my stat out to facilitate an air purge. Would that be the same as drilling holes??
Old Sep 5, 2007 | 11:47 PM
newbecorvetteguy's Avatar
newbecorvetteguy
That would be the same as leaving the thermostat out altogether.
Old Sep 5, 2007 | 11:56 PM
Sam Lam's Avatar
Sam Lam
Sum tin wong here
Old Sep 6, 2007 | 12:50 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Drilling should only be done if you need to relieve pressure from a high flow pump (does not apply on LT1s) or for purging air. And the OEM stats already have small holes in them for just that purpose.
Otherwise drilling it defeats the point of having a stat. 2 x 1/8" is too big IMO.
Old Sep 6, 2007 | 08:26 AM
Da Mail Man's Avatar
Da Mail Man
Old Sep 6, 2007 | 08:27 AM
BerniesVette's Avatar
BerniesVette
I agree with Coaster, you really don't have to drill the holes on an LT1. But I have been doing it for so long that I have drilled my T-stat on my 92 Vette. It runs around 190 to 195 in 95 to 100 degree temps. The car warms up quickly and maintains a good operating temp, so for me, it seems to work fine. Remember, even though our cars are similar, each car has its own individual quirks that can't be explained, and you have to find what works best for your car. If in doubt, your stock 180 t-stat should be fine; if you want to experiment by drilling your t-stat, it shouldn't cause a problem. Good luck!
Bernie
Old Sep 6, 2007 | 01:46 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
A single 1/16" hole will do the job, and holes won't make the engine run cooler or cool down faster.
Larry
code5coupe
__________
not easily impressed....
Old Sep 6, 2007 | 02:18 PM
CentralCoaster
I had a stat once with (3) 1/8" holes in it. It definitely ran cooler when you least wanted it.
I remember driving out of Frazier park in 20F weather, the car didn't want to stay over 120F, and was keeping the oil cold also. I put on my jacket and ran the a/c with the windows open to try and build up heat.
Old Sep 6, 2007 | 02:43 PM
JAKE's Avatar
JAKE
You should drill smaller holes for a stat used during the winter than one used during summer months.
TPIS' Hints booklet has the dimensions the holes should be, but I don't have access to mine right now.
Jake
Old Sep 7, 2007 | 10:04 AM
cdnguyred88's Avatar
cdnguyred88
Larry
code5coupe
__________
Have been doing it for over 8 years this way on my '88, tired of fighting the the air pockets.
To Drilled Thermostat?
Old Sep 7, 2007 | 10:09 AM
Demonic85's Avatar
Demonic85
I dont even think my stat works at all, the temp climbs all the way up to 230 and then drops to 195 with the fans. I thought about leaving it out but that didnt work so well last time I tried it, couldnt get over 128*
Old Sep 7, 2007 | 10:54 AM
CentralCoaster
Sound like you have a 195 stat. The coolant temp is supposed to be higher than that stat rating, that's entire point of the tstat, to keep the engine above a certain temp.
Old Sep 10, 2007 | 12:33 PM
ineVETTEable's Avatar
ineVETTEable
