removing TV cable from trans
Old Sep 6, 2007 | 12:06 PM
gator79's Avatar
gator79
Default removing TV cable from trans
what is the easiest way to get some slack in the TV cable at the ASR unit? I am trying to release it in the trans but need a little slack in the cable. thanks car is a 93
Old Sep 6, 2007 | 12:23 PM
Pete K's Avatar
Pete K
Blackroselt1 taught me a neat trick. Drop the pan and remove the 2 10 mm bolts that hold the tv bracket to the valvebody. This gives the needed slack, and is a great opportunity to swap out the filter also, all with almost no change in the tv adjusment.
Old Sep 6, 2007 | 08:32 PM
fredk's Avatar
fredk
From my experience follow Pete's advice. By the way how are ya Pete.
Fred
To removing TV cable from trans
