PCM for less guys need some help
Old Sep 7, 2007 | 04:15 PM
teufelhund's Avatar
teufelhund
Default PCM for less guys need some help
I just picked up a custom PCM chip from one of the other forum members. Everything looks to be the same except for a few things. For instance he has a mild cam on the chip (specs 204/214@ .050 and 422I/444E), he's also running a stock exhaust. I am running a stock cam but am running stock manifolds to dual exhaust with H pipe (no cats) and magnaflows on the rear. I was wondering if I'm safe going ahead and installing the chip as is and see what kind of power gain I get or should I have it flashed first.
Thanks for the replies ahead of time.
I have 86E BTW
Old Sep 7, 2007 | 04:45 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
personally, i would have the chip set (reflashed) for your vehicle... you jjust don't know the issues associated with a wrong program...
Since you say everything looks the same, except, are you reading the chip program?
Old Sep 7, 2007 | 06:22 PM
teufelhund's Avatar
teufelhund
I'm reading the order sheet that he gave me with the chip... The options he had on his vehicle.
Old Sep 7, 2007 | 06:54 PM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
Is it the EXACT same year, gears, transmission, etc, etc...
Alvin usually tunes those things EXACTLY to match the customer's car.
I'd get a reflash for your own car. I believe he can flash those chips multiple times... give him a call and see what he can do for you. He couldn't be any friendlier and helpful. Awesome guy to deal with.
Old Sep 7, 2007 | 07:12 PM
JackDidley's Avatar
JackDidley
If you have a way to datalog, then try the chip and watch the numbers. No datalog=no try. Its very possible that chip may have too much advance or even be too lean. These may hurt the motor.
Old Sep 7, 2007 | 07:14 PM
jwt1603's Avatar
jwt1603
I like the tune they did for me. Super helpful.
To PCM for less guys need some help
