Help Need Advice 94 Lt1
Old Sep 10, 2007 | 11:36 AM
dbone's Avatar
dbone
Cruising
Default Help Need Advice 94 Lt1
2 Part Question I. 94 Lt1 Stock Automatic Air Filter And Borla Exhaust The Only Upgrades. It Has New Plugs And Wires. Question 1 Does The Car Have A Rev Limiter? When You Get On It It Sputters At 6000 Rpm's. #2 Sputters Intermittently Lower Rpm's On Hard Acceleration . Thinking Dirty Injectors? Any Advivce Other Than That Car Runs Great
Old Sep 10, 2007 | 11:43 AM
clf93lt1's Avatar
clf93lt1
i think the Rev Limiter is set at 5850.
Old Sep 10, 2007 | 11:51 AM
NEVRL8T's Avatar
NEVRL8T
Yep and if it has the stock bottom end - I would stay away from twisting that thing up to 6000.
Old Sep 10, 2007 | 06:27 PM
clf93lt1's Avatar
clf93lt1
lot of people with head and cam work , are running over 6000 with the stock bottom end.
Old Sep 10, 2007 | 06:30 PM
aboatguy's Avatar
aboatguy
Old Sep 10, 2007 | 07:04 PM
wtn's Avatar
wtn
[QUOTE=dbone;1561855097]2 Part Question I. 94 Lt1 Stock Automatic Air Filter And Borla Exhaust The Only Upgrades. It Has New Plugs And Wires. Question 1 Does The Car Have A Rev Limiter? When You Get On It It Sputters At 6000 Rpm's. #2 Sputters Intermittently Lower Rpm's On Hard Acceleration . Thinking Dirty Injectors? Any Advivce Other Than That Car Runs Great[/QUOTE
If it is stock - do not run it past 5800 RPM. When it sputters at 6K the fuel rails are shutting off. Believe me - I have learned the hard way.
Old Sep 10, 2007 | 07:38 PM
dbone's Avatar
dbone
Cruising
Default rev limiter
The Car Is An Automatic Why Isn't It Shifting Prior To Hitting The Rev Limiter. And Does Anyone Have Advice About Dirty Injectors.
Old Sep 10, 2007 | 07:57 PM
Kinkajou's Avatar
Kinkajou
[QUOTE
=wtn;1561860637]
If it is stock - do not run it past 5800 RPM. When it sputters at 6K the fuel rails are shutting off. Believe me - I have learned the hard way.[/QUOTE]
What would be the problem? After all the engine shuts down to protect itself.
And what happens when using a Hypertech programmer, it will raise the RPM's it can reach.
Please explain a little on this
THANKS
Old Sep 10, 2007 | 08:12 PM
Road Agent's Avatar
Road Agent
How many times?
Old Sep 10, 2007 | 08:22 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
THANKS
Just because you can raise the rev limit RPM's, does not mean it's safe to do so or that your engine will hold together. Without modifications to the valve train and/or bottom end, you probably shouldn't be exceeding the factory redline.
To Help Need Advice 94 Lt1
